I am having the same issue, except mine doesn't report buggy like the op. I cannot seem to find a solution.
[root@freenas] ~# uname -a
FreeBSD freenas.local 9.3-RELEASE-p28 FreeBSD 9.3-RELEASE-p28 #0 r288272+f229c79: Sat Dec 12 11:58:01 PST 2015 root@build3.ixsystems.com:/tank/home/stable-builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
[root@freenas] /etc# /etc/ix.rc.d/ix-smartd start
tail -n 10 /var/log/messages
Dec 15 16:42:38 freenas notifier: smartd not running? (check /var/run/smartd.pid).
Dec 15 16:42:38 freenas notifier: Will not 'restart' smartd because smartd_enable is NO.
Dec 15 16:42:55 freenas notifier: Starting smartd.
Dec 15 16:42:55 freenas smartd[8051]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries (like /dev/hda)
Dec 15 16:42:55 freenas root: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
Dec 15 16:42:55 freenas notifier: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
[root@freenas] /etc# cat /usr/local/etc/smartd.conf
# smartd.conf generated by /etc/ix.rc.d/ix-smartd
[root@freenas] /etc# camcontrol devlist -v
scbus0 on ahcich0 bus 0:
<> at scbus0 target -1 lun -1 ()
scbus1 on ahcich1 bus 0:
<ST9160827AS 3.CMG> at scbus1 target 0 lun 0 (ada0,pass0)
<> at scbus1 target -1 lun -1 ()
scbus2 on ahcich2 bus 0:
<> at scbus2 target -1 lun -1 ()
scbus3 on ahcich3 bus 0:
<> at scbus3 target -1 lun -1 ()
scbus4 on ahcich4 bus 0:
<> at scbus4 target -1 lun -1 ()
scbus5 on ahcich5 bus 0:
<> at scbus5 target -1 lun -1 ()
scbus6 on camsim0 bus 0:
<> at scbus6 target -1 lun -1 ()
scbus7 on umass-sim0 bus 0:
<TOSHIBA TransMemory 1.00> at scbus7 target 0 lun 0 (pass1,da0)
scbus-1 on xpt0 bus 0:
<> at scbus-1 target -1 lun -1 (xpt0)
[root@freenas] ~# smartctl -a /dev/pass0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family: Seagate Momentus 5400.4
Device Model: ST9160827AS
Serial Number: 5RF33NTY
LU WWN Device Id: 5 000c50 01477a9cd
Firmware Version: 3.CMG
User Capacity: 160,041,885,696 bytes [160 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 1.5 Gb/s
Local Time is: Tue Dec 15 16:51:29 2015 CST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 426) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 60) minutes.
SCT capabilities: (0x0001) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 094 059 034 Pre-fail Always - 236187915
3 Spin_Up_Time 0x0003 100 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 079 079 020 Old_age Always - 22240
5 Reallocated_Sector_Ct 0x0033 098 098 036 Pre-fail Always - 102
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 4428332530
9 Power_On_Hours 0x0032 066 066 000 Old_age Always - 30009 (184 176 0)
10 Spin_Retry_Count 0x0013 100 100 034 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 977
184 End-to-End_Error 0x0032 100 253 000 Old_age Always - 0
187 Reported_Uncorrect 0x003a 001 001 000 Old_age Always - 2329
189 High_Fly_Writes 0x0022 001 001 045 Old_age Always FAILING_NOW 234
190 Airflow_Temperature_Cel 0x0032 065 036 000 Old_age Always - 35 (Min/Max 10/64)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 1565
192 Power-Off_Retract_Count 0x0022 100 001 000 Old_age Always - 69
193 Load_Cycle_Count 0x001a 089 089 000 Old_age Always - 22922
194 Temperature_Celsius 0x0012 035 064 000 Old_age Always - 35 (0 10 0 0 0)
195 Hardware_ECC_Recovered 0x0010 066 047 000 Old_age Offline - 236190989
196 Reallocated_Event_Count 0x003e 066 066 000 Old_age Always - 30054 (30598 0)
197 Current_Pending_Sector 0x0000 100 100 000 Old_age Offline - 18
198 Offline_Uncorrectable 0x0032 100 100 000 Old_age Always - 18
199 UDMA_CRC_Error_Count 0x0000 200 200 000 Old_age Offline - 0
200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0
202 Data_Address_Mark_Errs 0x0000 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 2333 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 2333 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
ER ST SC SN CL CH DH
40 51 00 5e a8 24 e0 Error: UNC at LBA = 0x0024a85e = 2402398
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 30 50 a8 24 e0 00 03:50:35.891 READ DMA EXT
27 00 00 00 00 00 e0 00 03:50:35.890 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 03:50:35.884 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 03:50:32.252 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 03:50:32.252 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 2332 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
25 00 30 50 a8 24 e0 00 03:50:24.956 READ DMA EXT
27 00 00 00 00 00 e0 00 03:50:24.955 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 03:50:24.948 IDENTIFY DEVICE
Error 2331 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
ef 03 45 00 00 00 a0 00 03:50:24.940 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 03:50:24.939 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 2330 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
Error 2329 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
25 00 30 50 a8 24 e0 00 03:50:17.477 READ DMA EXT
27 00 00 00 00 00 e0 00 03:50:17.477 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 03:50:17.477 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 03:50:17.476 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 03:50:17.476 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
# 1 Vendor (0x50) Completed without error 00% 1 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] ~# smartctl -d auto -a /dev/pass0
Local Time is: Tue Dec 15 16:52:17 2015 CST
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 094 059 034 Pre-fail Always - 236187927
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 4428332551
9 Power_On_Hours 0x0032 066 066 000 Old_age Always - 30009 (118 46 0)
195 Hardware_ECC_Recovered 0x0010 066 047 000 Old_age Offline - 236191005
196 Reallocated_Event_Count 0x003e 066 066 000 Old_age Always - 30054 (13572 0)
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
