[root@freenas ~]# dmesg
Waiting (max 60 seconds) for system process `vnlru' to stop... done
Waiting (max 60 seconds) for system process `bufdaemon' to stop... done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining... 0 0 0 0 0 0 0 0 done
All buffers synced.
Copyright (c) 1992-2018 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 11.2-STABLE #0 r325575+3b66a34f3aa(HEAD): Thu Feb 14 13:40:20 EST 2019
root@nemesis.tn.ixsystems.com:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)
VT(vga): resolution 640x480
CPU: AMD Phenom(tm) II X4 925 Processor (2800.07-MHz K8-class CPU)
Origin="AuthenticAMD" Id=0x100f42 Family=0x10 Model=0x4 Stepping=2
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x802009<SSE3,MON,CX16,POPCNT>
AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x37ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT>
SVM: (disabled in BIOS) NP,NRIP,NAsids=64
TSC: P-state invariant
real memory = 17716740096 (16896 MB)
avail memory = 16590786560 (15822 MB)
Event timer "LAPIC" quality 100
ACPI APIC Table: <HPQOEM SLIC-CPC>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 1.1> irqs 0-23 on motherboard
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1400035685 Hz quality 800
random: entropy device external interface
kbd1 at kbdmux0
nexus0
vtvga0: <VT VGA driver> on motherboard
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: No ACE support.
acpi0: <HPQOEM SLIC-CPC> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed00fff irq 2,8 on acpi0
Timecounter "HPET" frequency 25000000 Hz quality 950
attimer0: <AT timer> port 0x40-0x43 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x2008-0x200b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pcib0: _OSC returned error 0x10
pci0: <ACPI PCI bus> on pcib0
pci0: <memory, RAM> at device 0.0 (no driver attached)
isab0: <PCI-ISA bridge> port 0x2f00-0x2fff at device 1.0 on pci0
isa0: <ISA bus> on isab0
pci0: <memory, RAM> at device 1.2 (no driver attached)
pci0: <processor> at device 1.3 (no driver attached)
pci0: <memory, RAM> at device 1.4 (no driver attached)
ohci0: <OHCI (generic) USB controller> mem 0xfe87f000-0xfe87ffff irq 22 at device 2.0 on pci0
usbus0 on ohci0
usbus0: 12Mbps Full Speed USB v1.0
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe87ec00-0xfe87ecff irq 23 at device 2.1 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
usbus1: 480Mbps High Speed USB v2.0
ohci1: <OHCI (generic) USB controller> mem 0xfe87d000-0xfe87dfff irq 20 at device 4.0 on pci0
usbus2 on ohci1
usbus2: 12Mbps Full Speed USB v1.0
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe87e800-0xfe87e8ff irq 21 at device 4.1 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci1
usbus3: 480Mbps High Speed USB v2.0
pcib1: <ACPI PCI-PCI bridge> at device 8.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pci1: <serial bus, FireWire> at device 5.0 (no driver attached)
ahci0: <NVIDIA MCP77 AHCI SATA controller> port 0xc480-0xc487,0xc400-0xc403,0xc080-0xc087,0xc000-0xc003,0xbc00-0xbc0f mem 0xfe87a000-0xfe87bfff irq 22 at device 9.0 on pci0
ahci0: AHCI v1.20 with 4 3Gbps ports, Port Multiplier supported
ahci0: quirks=0x200<NOAA>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 16.0 on pci0
pci2: <ACPI PCI bus> on pcib2
vgapci0: <VGA-compatible display> port 0xd000-0xd0ff mem 0xe0000000-0xefffffff,0xfeac0000-0xfeafffff irq 16 at device 0.0 on pci2
vgapci0: Boot video device
pci2: <multimedia, HDA> at device 0.1 (no driver attached)
pcib3: <ACPI PCI-PCI bridge> irq 17 at device 18.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 18 at device 19.0 on pci0
pci4: <ACPI PCI bus> on pcib4
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xe800-0xe8ff mem 0xfebff000-0xfebfffff,0xfdffc000-0xfdffffff irq 18 at device 0.0 on pci4
re0: Using 1 MSI-X message
re0: Chip rev. 0x4c000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8251 1000BASE-T media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Using defaults for TSO: 65518/35/2048
re0: Ethernet address: 00:e0:4c:6e:09:4d
pcib5: <ACPI PCI-PCI bridge> irq 19 at device 20.0 on pci0
pci5: <ACPI PCI bus> on pcib5
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb3
amdtemp0: Erratum 319: temperature measurement may be inaccurate
acpi_button0: <Power Button> on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xcffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
freenas_sysctl: adding account.
freenas_sysctl: adding directoryservice.
freenas_sysctl: adding middlewared.
freenas_sysctl: adding network.
freenas_sysctl: adding services.
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen2.1: <nVidia OHCI root HUB> at usbus2
ugen0.1: <nVidia OHCI root HUB> at usbus0
ugen3.1: <nVidia EHCI root HUB> at usbus3
ugen1.1: <nVidia EHCI root HUB> at usbus1
uhub0: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
uhub1: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
uhub2: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
uhub3: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub2: 1 port with 1 removable, self powered
uhub0: 2 ports with 2 removable, self powered
uhub3: 1 port with 1 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen2.2: <LITE-ON Technology USB NetVista Full Width Keyboard.> at usbus2
ukbd0 on uhub0
ukbd0: <EP1 Interrupt> on usbus2
kbd2 at ukbd0
ugen1.2: <Kingston DataTraveler 3.0> at usbus1
umass0 on uhub3
umass0: <Kingston DataTraveler 3.0, class 0/0, rev 2.10/0.01, addr 2> on usbus1
umass0: SCSI over Bulk-Only; quirks = 0xc100
umass0:5:0: Attached to scbus5
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EZRZ-00Z5HB0 80.00A80> ACS-2 ATA SATA 3.x device
ada0: Serial Number WD-WCC4M5XJSXZ1
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors)
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD20EZRX-00D8PB0 80.00A80> ACS-2 ATA SATA 3.x device
ada1: Serial Number WD-WCC4M0303149
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors)
ada1: quirks=0x1<4K>
random: unblocking device.
da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
da0: <Kingston DataTraveler 3.0 > Removable Direct Access SPC-4 SCSI device
da0: Serial Number 60A44C413C4EF231398A05C4
da0: 40.000MB/s transfers
da0: 14755MB (30218842 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
Trying to mount root from zfs:freenas-boot/ROOT/11.2-U2 []...
(da0:umass-sim0:0:0:0): UNMAP failed, switching to WRITE SAME(16) with UNMAP BIO_DELETE
(da0:umass-sim0:0:0:0): UNMAP. CDB: 42 00 00 00 00 00 00 03 98 00
(da0:umass-sim0:0:0:0): CAM status: SCSI Status Error
(da0:umass-sim0:0:0:0): SCSI status: Check Condition
(da0:umass-sim0:0:0:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code)
(da0:umass-sim0:0:0:0): Error 22, Unretryable error
(da0:umass-sim0:0:0:0): WRITE SAME(16) with UNMAP failed, switching to WRITE SAME(10) with UNMAP BIO_DELETE
(da0:umass-sim0:0:0:0): WRITE SAME(16). CDB: 93 08 00 00 00 00 01 60 24 29 00 00 00 04 00 00
(da0:umass-sim0:0:0:0): WRITE SAME(10) with UNMAP failed, disabling BIO_DELETE
(da0:umass-sim0:0:0:0): WRITE SAME(10). CDB: 41 08 00 08 24 3f 00 00 05 00
re0: link state changed to UP
Syncing disks, vnodes remaining... 0 0 done
All buffers synced.
Uptime: 11m21s
CPU: AMD Phenom(tm) II X4 925 Processor (2800.06-MHz K8-class CPU)
Timecounter "TSC-low" frequency 1400032134 Hz quality 800
kbd1 at kbdmux0
nexus0
usbus0 on ohci0
usbus1 on ehci0
usbus2 on ohci1
usbus3 on ehci1
kbd0 at atkbd0
uhub0: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
uhub2: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
uhub3: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
uhub1: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub2: 2 ports with 2 removable, self powered
uhub1: 1 port with 1 removable, self powered
ukbd0 on uhub2
kbd2 at ukbd0
umass0 on uhub1
(da0:umass-sim0:0:0:0): UNMAP. CDB: 42 00 00 00 00 00 00 04 08 00
(da0:umass-sim0:0:0:0): WRITE SAME(16). CDB: 93 08 00 00 00 00 01 68 36 40 00 00 00 60 00 00
(da0:umass-sim0:0:0:0): WRITE SAME(10). CDB: 41 08 01 68 36 c0 00 01 20 00
SVM: disabled by BIOS.
module_register_init: MOD_LOAD (vmm, 0xffffffff82a24470, 0) error 6
GEOM_MIRROR: Device mirror/swap0 launched (2/2).
GEOM_ELI: Device mirror/swap0.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: software
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> K8/4/48/0x1ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA>
re0: link state changed to DOWN
bridge0: Ethernet address: 02:4d:4e:ad:6d:00
re0: promiscuous mode enabled
bridge0: link state changed to UP
epair0a: Ethernet address: 02:22:10:00:04:0a
epair0b: Ethernet address: 02:22:10:00:05:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: promiscuous mode enabled
Syncing disks, vnodes remaining... 0 0 0 0 0 0 0 done
All buffers synced.
