Over the last few weeks I keep getting the following error:
Zpool status tells me that a small amount of data has been resilvered. The size of the data has always been different the three times that this has happened so far (156K, 180K, now 80K):
Everytime this happens I run an extended SMART test to find any problems with the drive, but each time no errors are reported.
Just to make sure I wasn't testing the wrong disk, I went into the FreeNAS Volume Status > Edit Disk to pull the serial number of the problem disk. I confirmed that I was checking the problem disk via this method. When I received the particular disk about four months ago, Newegg shipped it in a bubble wrap HDD sleeve. A few of the bubbles, which are few and span the length of the disk, were completely deflated. I did an extended SMART test and a badblocks -wsv test on the drive when I received it, but no problems were revealed so I didn't send the drive back to Newegg.
All the drives in the NAS are WD40EFRX connected to an IT flashed IBM ServeRAID M1015 via mini-SAS to SATA cables. I am using 32GB ECC RAM in this system. I'd appreciate any help in trying to fix this problem. I've already RMA'd two of the WD40EFRX drives that were in the system, but they had SMART test errors. Since this particular drive keeps passing the SMART tests, I'm afraid of sending it in for an Advanced RMA and getting charged for sending in a good drive.
Thanks in advance for any help.
> (da4:mps0:0:6:0): WRITE(16). CDB: 8a 00 00 00 00 01 18 48 3f 90 00 00 00 08 00 00 > (da4:mps0:0:6:0): CAM status: SCSI Status Error > (da4:mps0:0:6:0): SCSI status: Check Condition > (da4:mps0:0:6:0): SCSI sense: ILLEGAL REQUEST asc:21,0 (Logical block address out of range) > (da4:mps0:0:6:0): Info: 0x118483f90 > (da4:mps0:0:6:0): Error 22, Unretryable error
pool: tank1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: resilvered 80K in 0h0m with 0 errors on Sun Feb 16 13:34:37 2014
NAME STATE READ WRITE CKSUM
tank1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/6177eafb-4c2c-11e3-a43a-002590d72d3b ONLINE 0 0 0
gptid/91cabea9-8b48-11e3-a7b6-002590d72d3b ONLINE 0 0 0
gptid/634c34ad-4c2c-11e3-a43a-002590d72d3b ONLINE 0 0 0
gptid/64368d6a-4c2c-11e3-a43a-002590d72d3b ONLINE 0 0 0
gptid/6524b559-4c2c-11e3-a43a-002590d72d3b ONLINE 0 0 0
gptid/6a4eecce-75d3-11e3-8a04-002590d72d3b ONLINE 0 1 0
logs
gptid/349c2eca-4c2d-11e3-a43a-002590d72d3b ONLINE 0 0 0
errors: No known data errorsEverytime this happens I run an extended SMART test to find any problems with the drive, but each time no errors are reported.
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E0477430
LU WWN Device Id: 5 0014ee 2b3e0e355
Firmware Version: 80.00A80
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Feb 17 06:45:10 2014 EST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (53760) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 537) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 178 176 021 Pre-fail Always - 8100
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 24
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1100
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 24
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 21
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 12736
194 Temperature_Celsius 0x0022 122 095 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 1093 -
# 2 Extended offline Completed without error 00% 1073 -
# 3 Extended offline Interrupted (host reset) 10% 1056 - (Note: I rebooted the server before this test finished)
# 4 Short offline Completed without error 00% 1045 -
# 5 Short offline Completed without error 00% 1021 -
# 6 Short offline Completed without error 00% 997 -
# 7 Short offline Completed without error 00% 974 -
# 8 Short offline Completed without error 00% 950 -
# 9 Short offline Completed without error 00% 926 -
#10 Short offline Completed without error 00% 902 -
#11 Short offline Completed without error 00% 878 -
#12 Extended offline Completed without error 00% 867 -
#13 Short offline Completed without error 00% 857 -
#14 Short offline Completed without error 00% 854 -
#15 Short offline Completed without error 00% 830 -
#16 Short offline Completed without error 00% 806 -
#17 Extended offline Completed without error 00% 794 -
#18 Short offline Completed without error 00% 782 -
#19 Short offline Completed without error 00% 758 -
#20 Short offline Completed without error 00% 734 -
#21 Short offline Completed without error 00% 715 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
