Unable to add Jails and Plugins
striker79
Hello all,
I am fairly new to Freenas. I initially built my system to use with Plex, and it had been working great, but then I started having network issues. I thought I would just delete the plugin for plex along with the jail, and create them fresh, but now I am unable to Add Jails, and Plugins show up empty.
I am also unable to see all my data on my mapped drive, but I don't think I lost any because the Volume in freenas still has a lot of space taken up.
What do I do!?! Please help!
striker79
Not that I am aware of. I have an RT-AC87U and completely reset the router thinking maybe there was a conflict.
striker79
Here is what I am seeing...
nojohnny101
well that picture #2 makes sense because there is not jail installed to add storage to. not sure about #3.
I know others on here have no problems with plugins but I initially did when I was setting up my system and so I found this thread:
Install Plex from CLI
It is very straightforward and mine has been rock solid ever since. I know this isn't really finding out what happened or fixing your problem directly.
What changed when started having network problems? That is the first question I always ask myself.
This is very vague and nondescript. Can you provide more details and think back to see if anything changed in your network setup or your freenas box (updates, etc.)?
Let's start there.
striker79
Initially everything had been working just fine, but then I noticed my router would keep resetting itself under heavy load. It seemed it was just getting too hot, so I tried a different router, but could not get plex to be available remotely, even though I forwarded port 32400. I then figured I would just factory reset the original RT-AC87U router and put a fan on it, but then I could not get plex to work on any of my devices. I tried setting up static IPs, but that didn't seem to help either. It's as if everything magically stopped working. So I thought maybe a setting had changed in Freenas. I logged into freenas and checked my network settings and everything was the same, but still wasn't working. I know this is still pretty vague, and I am usually good about getting things like this to work, but this whole thing has just blown my mind.
striker79
Let's start there.
I just tried the link you posted but I get "Unable to find Template"
Sakuru
Under the Jails tab --> Configuration, what is your Jail Root set to?
striker79
Jailer
Not strong, but bad
You need to create a dataset for your template to reside in. It will not install to the root of your Pool.
striker79
Like this...
Sakuru
Jailer
Not strong, but bad
Like this...
Yes. Now change your jails configuration tab to point to the dataset you just created and try downloading the template again.
striker79
I just tried and still get "unable to find template"
Jailer
Not strong, but bad
Is there any templates listed on the templates tab?
striker79
Just this one
MisterIce
And sending a ping from the shell is working?
For example:
ping -c 5 www.microsoft.com
Jailer
Not strong, but bad
My guess is that you have some bits left over from your previous template download that are likely still in your Pool root. Can you list the output of
zfs list -t snapshot | grep '.warden-template'
striker79
Ping doesn't seem to be working?
