leonardorame
- Jun 30, 2018
Hi, in a FreeNAS-11.0-U1 (aa82cc58d) I found this:
Last week I found one disk (ada2) was in an error state (I don't have a screenshot) and bought a new one and replaced it. At that moment ada0 and ada1 where ONLINE, but now I found them are in a DEGRADED state, what can have caused that?.
Here's the smartctl -x for ada0:
And for ada1:
root@freenas:~ # smartctl -x /dev/ada0 smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Skyhawk Device Model: ST4000VX007-2DT166 Serial Number: ZM415GCE LU WWN Device Id: 5 000c50 0c59735e6 Firmware Version: CV11 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5980 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Jun 28 14:01:30 2021 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 591) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 667) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-- 077 064 044 - 54778424 3 Spin_Up_Time PO---- 094 093 000 - 0 4 Start_Stop_Count -O--CK 100 100 020 - 28 5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0 7 Seek_Error_Rate POSR-- 092 060 045 - 1591862378 9 Power_On_Hours -O--CK 091 091 000 - 8399h+00m+00.000s 10 Spin_Retry_Count PO--C- 100 100 097 - 0 12 Power_Cycle_Count -O--CK 100 100 020 - 28 184 End-to-End_Error -O--CK 100 100 099 - 0 187 Reported_Uncorrect -O--CK 100 100 000 - 0 188 Command_Timeout -O--CK 100 001 000 - 1507556720639 189 High_Fly_Writes -O-RCK 100 100 000 - 0 190 Airflow_Temperature_Cel -O---K 072 056 040 - 28 (Min/Max 17/29) 191 G-Sense_Error_Rate -O--CK 100 100 000 - 0 192 Power-Off_Retract_Count -O--CK 100 100 000 - 27 193 Load_Cycle_Count -O--CK 099 099 000 - 3554 194 Temperature_Celsius -O---K 028 044 000 - 28 (0 14 0 0 0) 197 Current_Pending_Sector -O--C- 100 100 000 - 0 198 Offline_Uncorrectable ----C- 100 100 000 - 0 199 UDMA_CRC_Error_Count -OSRCK 200 156 000 - 20111105 240 Head_Flying_Hours ------ 100 253 000 - 8382h+06m+20.964s 241 Total_LBAs_Written ------ 100 253 000 - 28230124196 242 Total_LBAs_Read ------ 100 253 000 - 27291687424 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 5 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x08 GPL R/O 2 Power Conditions log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 SATA NCQ Queued Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x13 GPL R/O 1 SATA NCQ Send and Receive log 0x15 GPL R/W 1 SATA Rebuild Assist log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x24 GPL R/O 512 Current Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa1 GPL,SL VS 24 Device vendor specific log 0xa2 GPL VS 8160 Device vendor specific log 0xa6 GPL VS 192 Device vendor specific log 0xa8-0xa9 GPL,SL VS 136 Device vendor specific log 0xab GPL VS 1 Device vendor specific log 0xb0 GPL VS 9048 Device vendor specific log 0xbe-0xbf GPL VS 65535 Device vendor specific log 0xc1 GPL,SL VS 16 Device vendor specific log 0xd1 GPL VS 136 Device vendor specific log 0xd2 GPL VS 10000 Device vendor specific log 0xd3 GPL VS 1920 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (5 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 522 (0x020a) SCT Support Level: 1 Device State: Active (0) Current Temperature: 28 Celsius Power Cycle Min/Max Temperature: 17/29 Celsius Lifetime Min/Max Temperature: 14/44 Celsius Under/Over Temperature Limit Count: 0/56 SCT Temperature History Version: 2 Temperature Sampling Period: 3 minutes Temperature Logging Interval: 59 minutes Min/Max recommended Temperature: 0/ 0 Celsius Min/Max Temperature Limit: 0/ 0 Celsius Temperature History Size (Index): 128 (119) Index Estimated Time Temperature Celsius 120 2021-06-23 08:52 27 ******** ... ..( 16 skipped). .. ******** 9 2021-06-24 01:35 27 ******** 10 2021-06-24 02:34 28 ********* 11 2021-06-24 03:33 27 ******** ... ..( 3 skipped). .. ******** 15 2021-06-24 07:29 27 ******** 16 2021-06-24 08:28 26 ******* 17 2021-06-24 09:27 24 ***** 18 2021-06-24 10:26 24 ***** 19 2021-06-24 11:25 24 ***** 20 2021-06-24 12:24 25 ****** ... ..( 11 skipped). .. ****** 32 2021-06-25 00:12 25 ****** 33 2021-06-25 01:11 26 ******* 34 2021-06-25 02:10 26 ******* 35 2021-06-25 03:09 25 ****** ... ..( 9 skipped). .. ****** 45 2021-06-25 12:59 25 ****** 46 2021-06-25 13:58 26 ******* 47 2021-06-25 14:57 26 ******* 48 2021-06-25 15:56 27 ******** 49 2021-06-25 16:55 27 ******** 50 2021-06-25 17:54 26 ******* 51 2021-06-25 18:53 27 ******** 52 2021-06-25 19:52 28 ********* ... ..( 2 skipped). .. ********* 55 2021-06-25 22:49 28 ********* 56 2021-06-25 23:48 29 ********** 57 2021-06-26 00:47 28 ********* 58 2021-06-26 01:46 28 ********* 59 2021-06-26 02:45 29 ********** 60 2021-06-26 03:44 28 ********* 61 2021-06-26 04:43 29 ********** 62 2021-06-26 05:42 29 ********** 63 2021-06-26 06:41 ? - 64 2021-06-26 07:40 17 - 65 2021-06-26 08:39 28 ********* 66 2021-06-26 09:38 28 ********* 67 2021-06-26 10:37 27 ******** ... ..( 6 skipped). .. ******** 74 2021-06-26 17:30 27 ******** 75 2021-06-26 18:29 26 ******* 76 2021-06-26 19:28 26 ******* 77 2021-06-26 20:27 25 ****** 78 2021-06-26 21:26 25 ****** 79 2021-06-26 22:25 26 ******* 80 2021-06-26 23:24 26 ******* 81 2021-06-27 00:23 25 ****** ... ..( 7 skipped). .. ****** 89 2021-06-27 08:15 25 ****** 90 2021-06-27 09:14 24 ***** ... ..( 3 skipped). .. ***** 94 2021-06-27 13:10 24 ***** 95 2021-06-27 14:09 25 ****** 96 2021-06-27 15:08 24 ***** 97 2021-06-27 16:07 24 ***** 98 2021-06-27 17:06 24 ***** 99 2021-06-27 18:05 26 ******* ... ..( 2 skipped). .. ******* 102 2021-06-27 21:02 26 ******* 103 2021-06-27 22:01 27 ******** ... ..( 6 skipped). .. ******** 110 2021-06-28 04:54 27 ******** 111 2021-06-28 05:53 24 ***** 112 2021-06-28 06:52 23 **** 113 2021-06-28 07:51 22 *** 114 2021-06-28 08:50 23 **** 115 2021-06-28 09:49 23 **** 116 2021-06-28 10:48 24 ***** 117 2021-06-28 11:47 26 ******* 118 2021-06-28 12:46 26 ******* 119 2021-06-28 13:45 26 ******* SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 28 --- Lifetime Power-On Resets 0x01 0x010 4 8399 --- Power-on Hours 0x01 0x018 6 28234530564 --- Logical Sectors Written 0x01 0x020 6 367531079 --- Number of Write Commands 0x01 0x028 6 27291745195 --- Logical Sectors Read 0x01 0x030 6 230819784 --- Number of Read Commands 0x01 0x038 6 - --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 504649057 N-- Spindle Motor Power-on Hours 0x03 0x010 4 504644007 N-- Head Flying Hours 0x03 0x018 4 3554 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 0 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors 0x03 0x040 4 28 --- Number of High Priority Unload Events 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 12507694 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 28 --- Current Temperature 0x05 0x010 1 25 --- Average Short Term Temperature 0x05 0x018 1 27 --- Average Long Term Temperature 0x05 0x020 1 44 --- Highest Temperature 0x05 0x028 1 0 --- Lowest Temperature 0x05 0x030 1 41 --- Highest Average Short Term Temperature 0x05 0x038 1 22 --- Lowest Average Short Term Temperature 0x05 0x040 1 35 --- Highest Average Long Term Temperature 0x05 0x048 1 27 --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 70 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 20157961 --- Number of Hardware Resets 0x06 0x010 4 4 --- Number of ASR Events 0x06 0x018 4 20115232 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x000a 2 3 Device-to-host register FISes sent due to a COMRESET 0x0001 2 0 Command failed due to ICRC error 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS
And for ada1:
root@freenas:~ # smartctl -x /dev/ada1 smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Skyhawk Device Model: ST4000VX007-2DT166 Serial Number: ZM416KPA LU WWN Device Id: 5 000c50 0c5974573 Firmware Version: CV11 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5980 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Jun 28 14:02:16 2021 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 591) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 648) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-- 076 064 044 - 39658584 3 Spin_Up_Time PO---- 094 093 000 - 0 4 Start_Stop_Count -O--CK 100 100 020 - 17 5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0 7 Seek_Error_Rate POSR-- 092 060 045 - 1670553496 9 Power_On_Hours -O--CK 093 093 000 - 6373h+00m+00.000s 10 Spin_Retry_Count PO--C- 100 100 097 - 0 12 Power_Cycle_Count -O--CK 100 100 020 - 17 184 End-to-End_Error -O--CK 100 100 099 - 0 187 Reported_Uncorrect -O--CK 100 100 000 - 0 188 Command_Timeout -O--CK 100 100 000 - 0 189 High_Fly_Writes -O-RCK 100 100 000 - 0 190 Airflow_Temperature_Cel -O---K 071 051 040 - 29 (Min/Max 17/30) 191 G-Sense_Error_Rate -O--CK 100 100 000 - 0 192 Power-Off_Retract_Count -O--CK 100 100 000 - 23 193 Load_Cycle_Count -O--CK 100 100 000 - 93 194 Temperature_Celsius -O---K 029 049 000 - 29 (0 15 0 0 0) 197 Current_Pending_Sector -O--C- 100 100 000 - 0 198 Offline_Uncorrectable ----C- 100 100 000 - 0 199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0 240 Head_Flying_Hours ------ 100 253 000 - 6370h+54m+09.513s 241 Total_LBAs_Written ------ 100 253 000 - 16361558708 242 Total_LBAs_Read ------ 100 253 000 - 90986079404 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 5 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x08 GPL R/O 2 Power Conditions log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 SATA NCQ Queued Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x13 GPL R/O 1 SATA NCQ Send and Receive log 0x15 GPL R/W 1 SATA Rebuild Assist log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x24 GPL R/O 512 Current Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa1 GPL,SL VS 24 Device vendor specific log 0xa2 GPL VS 8160 Device vendor specific log 0xa6 GPL VS 192 Device vendor specific log 0xa8-0xa9 GPL,SL VS 136 Device vendor specific log 0xab GPL VS 1 Device vendor specific log 0xb0 GPL VS 9048 Device vendor specific log 0xbe-0xbf GPL VS 65535 Device vendor specific log 0xc1 GPL,SL VS 16 Device vendor specific log 0xd1 GPL VS 136 Device vendor specific log 0xd2 GPL VS 10000 Device vendor specific log 0xd3 GPL VS 1920 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (5 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 522 (0x020a) SCT Support Level: 1 Device State: Active (0) Current Temperature: 29 Celsius Power Cycle Min/Max Temperature: 17/30 Celsius Lifetime Min/Max Temperature: 15/49 Celsius Under/Over Temperature Limit Count: 0/56 SCT Temperature History Version: 2 Temperature Sampling Period: 3 minutes Temperature Logging Interval: 59 minutes Min/Max recommended Temperature: 0/ 0 Celsius Min/Max Temperature Limit: 0/ 0 Celsius Temperature History Size (Index): 128 (22) Index Estimated Time Temperature Celsius 23 2021-06-23 08:52 27 ******** ... ..( 21 skipped). .. ******** 45 2021-06-24 06:30 27 ******** 46 2021-06-24 07:29 25 ****** 47 2021-06-24 08:28 24 ***** ... ..( 2 skipped). .. ***** 50 2021-06-24 11:25 24 ***** 51 2021-06-24 12:24 25 ****** 52 2021-06-24 13:23 24 ***** 53 2021-06-24 14:22 25 ****** ... ..( 19 skipped). .. ****** 73 2021-06-25 10:02 25 ****** 74 2021-06-25 11:01 24 ***** 75 2021-06-25 12:00 25 ****** 76 2021-06-25 12:59 25 ****** 77 2021-06-25 13:58 26 ******* ... ..( 2 skipped). .. ******* 80 2021-06-25 16:55 26 ******* 81 2021-06-25 17:54 27 ******** 82 2021-06-25 18:53 27 ******** 83 2021-06-25 19:52 28 ********* ... ..( 9 skipped). .. ********* 93 2021-06-26 05:42 28 ********* 94 2021-06-26 06:41 ? - 95 2021-06-26 07:40 17 - 96 2021-06-26 08:39 29 ********** 97 2021-06-26 09:38 28 ********* 98 2021-06-26 10:37 28 ********* 99 2021-06-26 11:36 29 ********** ... ..( 2 skipped). .. ********** 102 2021-06-26 14:33 29 ********** 103 2021-06-26 15:32 28 ********* 104 2021-06-26 16:31 28 ********* 105 2021-06-26 17:30 28 ********* 106 2021-06-26 18:29 27 ******** 107 2021-06-26 19:28 26 ******* ... ..( 4 skipped). .. ******* 112 2021-06-27 00:23 26 ******* 113 2021-06-27 01:22 25 ****** ... ..( 15 skipped). .. ****** 1 2021-06-27 17:06 25 ****** 2 2021-06-27 18:05 26 ******* 3 2021-06-27 19:04 27 ******** 4 2021-06-27 20:03 27 ******** 5 2021-06-27 21:02 27 ******** 6 2021-06-27 22:01 28 ********* 7 2021-06-27 23:00 28 ********* 8 2021-06-27 23:59 27 ******** ... ..( 4 skipped). .. ******** 13 2021-06-28 04:54 27 ******** 14 2021-06-28 05:53 25 ****** 15 2021-06-28 06:52 23 **** 16 2021-06-28 07:51 23 **** 17 2021-06-28 08:50 24 ***** 18 2021-06-28 09:49 24 ***** 19 2021-06-28 10:48 24 ***** 20 2021-06-28 11:47 26 ******* 21 2021-06-28 12:46 27 ******** 22 2021-06-28 13:45 27 ******** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 17 --- Lifetime Power-On Resets 0x01 0x010 4 6373 --- Power-on Hours 0x01 0x018 6 16365677452 --- Logical Sectors Written 0x01 0x020 6 198300910 --- Number of Write Commands 0x01 0x028 6 91024179407 --- Logical Sectors Read 0x01 0x030 6 619456950 --- Number of Read Commands 0x01 0x038 6 - --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 2734587694 N-- Spindle Motor Power-on Hours 0x03 0x010 4 2734583962 N-- Head Flying Hours 0x03 0x018 4 93 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 0 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors 0x03 0x040 4 24 --- Number of High Priority Unload Events 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 29 --- Current Temperature 0x05 0x010 1 25 --- Average Short Term Temperature 0x05 0x018 1 30 --- Average Long Term Temperature 0x05 0x020 1 49 --- Highest Temperature 0x05 0x028 1 0 --- Lowest Temperature 0x05 0x030 1 46 --- Highest Average Short Term Temperature 0x05 0x038 1 24 --- Lowest Average Short Term Temperature 0x05 0x040 1 39 --- Highest Average Long Term Temperature 0x05 0x048 1 30 --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 70 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 32 --- Number of Hardware Resets 0x06 0x010 4 0 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x000a 2 3 Device-to-host register FISes sent due to a COMRESET 0x0001 2 0 Command failed due to ICRC error 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS
