Freenas 11.1-U4
Intel i3-6100
Samsung 16GB DDR4 2133 ECC X8 2R ( M391A2K43BB1-CPB)
Supermicro X11SSL-CF
Data: 7x Toshiba DT01ACA300
Boot: Samsung 830 SSD
Corsair RM750x
Received the Offline uncorrectable sectors CRITICAL ALERT which is still flashing in status, but SMART checks out OK.
Intel i3-6100
Corsair RM750x
Aug 12 09:06:28 FreeNAS_NAS1 smartd[3065]: Device: /dev/ada3, 1 Offline uncorrectable sectors Aug 12 09:06:29 FreeNAS_NAS1 smartd[3065]: Device: /dev/ada3, 1 Offline uncorrectable sectors Aug 13 00:00:00 FreeNAS_NAS1 syslog-ng[5775]: Configuration reload request received, reloading configuration;
zpool status pool: NAS1-pool1 state: ONLINE scan: scrub repaired 0 in 0 days 00:24:39 with 0 errors on Fri Aug 10 02:24:42 2018 config: NAME STATE READ WRITE CKSUM NAS1-pool1 ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/7442e5da-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0 gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli ONLINE 0 0 0 mirror-1 ONLINE 0 0 0 gptid/7dd9ce06-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0 gptid/813153f4-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0 mirror-2 ONLINE 0 0 0 gptid/8790b712-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0 gptid/8af9d490-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0 spares gptid/36f62083-7d28-11e8-949e-0cc47a868d02.eli AVAIL errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:00:04 with 0 errors on Fri Aug 10 03:45:04 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 ada2p2 ONLINE 0 0 0 errors: No known data errors
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Toshiba 3.5" DT01ACA... Desktop HDD Device Model: TOSHIBA DT01ACA300 Serial Number: 66UAJN1AS LU WWN Device Id: 5 000039 fe3d2e1b4 Firmware Version: MX6OABB0 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Aug 13 06:50:48 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Disabled Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (22508) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 376) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0 2 Throughput_Performance P-S--- 140 140 054 - 68 3 Spin_Up_Time POS--- 134 134 024 - 428 (Average 425) 4 Start_Stop_Count -O--C- 100 100 000 - 99 5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0 7 Seek_Error_Rate PO-R-- 100 100 067 - 0 8 Seek_Time_Performance P-S--- 124 124 020 - 33 9 Power_On_Hours -O--C- 100 100 000 - 3785 10 Spin_Retry_Count PO--C- 100 100 060 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 99 192 Power-Off_Retract_Count -O--CK 100 100 000 - 445 193 Load_Cycle_Count -O--C- 100 100 000 - 445 194 Temperature_Celsius -O---- 157 157 000 - 38 (Min/Max 17/47) 196 Reallocated_Event_Count -O--CK 100 100 000 - 0 197 Current_Pending_Sector -O---K 100 100 000 - 0 198 Offline_Uncorrectable ---R-- 100 100 000 - 0 199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x03 GPL R/O 1 Ext. Comprehensive SMART error log 0x04 GPL R/O 7 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x08 GPL R/O 2 Power Conditions log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x20 GPL R/O 1 Streaming performance log [OBS-8] 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (1 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 3705 - # 2 Short offline Completed without error 00% 3609 - # 3 Extended offline Completed without error 00% 3544 - # 4 Short offline Completed without error 00% 3513 - # 5 Short offline Completed without error 00% 3441 - # 6 Short offline Completed without error 00% 3345 - # 7 Short offline Completed without error 00% 3249 - # 8 Extended offline Completed without error 00% 3184 - # 9 Short offline Completed without error 00% 3153 - #10 Short offline Completed without error 00% 3057 - #11 Short offline Completed without error 00% 2961 - #12 Short offline Completed without error 00% 2865 - #13 Extended offline Completed without error 00% 2800 - #14 Short offline Completed without error 00% 2769 - #15 Short offline Completed without error 00% 2722 - #16 Short offline Completed without error 00% 2633 - #17 Extended offline Completed without error 00% 2568 - #18 Short offline Completed without error 00% 2537 - #19 Short offline Completed without error 00% 2441 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 256 (0x0100) SCT Support Level: 1 Device State: Active (0) Current Temperature: 38 Celsius Power Cycle Min/Max Temperature: 30/42 Celsius Lifetime Min/Max Temperature: 17/47 Celsius Under/Over Temperature Limit Count: 0/0 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -40/70 Celsius Temperature History Size (Index): 128 (39) Index Estimated Time Temperature Celsius 40 2018-08-13 04:43 38 ******************* ... ..(126 skipped). .. ******************* 39 2018-08-13 06:50 38 ******************* SCT Error Recovery Control: Read: Disabled Write: Disabled Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 99 --- Lifetime Power-On Resets 0x01 0x010 4 3785 --- Power-on Hours 0x01 0x018 6 78479836458 --- Logical Sectors Written 0x01 0x020 6 265748294 --- Number of Write Commands 0x01 0x028 6 70942285709 --- Logical Sectors Read 0x01 0x030 6 218062491 --- Number of Read Commands 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 3784 --- Spindle Motor Power-on Hours 0x03 0x010 4 3784 --- Head Flying Hours 0x03 0x018 4 445 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 10 --- Read Recovery Attempts 0x03 0x030 4 7 --- Number of Mechanical Start Failures 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 38 --- Current Temperature 0x05 0x010 1 38 N-- Average Short Term Temperature 0x05 0x018 1 37 N-- Average Long Term Temperature 0x05 0x020 1 47 --- Highest Temperature 0x05 0x028 1 17 --- Lowest Temperature 0x05 0x030 1 43 N-- Highest Average Short Term Temperature 0x01 0x030 6 218062491 --- Number of Read Commands 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 3784 --- Spindle Motor Power-on Hours 0x03 0x010 4 3784 --- Head Flying Hours 0x03 0x018 4 445 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 10 --- Read Recovery Attempts 0x03 0x030 4 7 --- Number of Mechanical Start Failures 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 38 --- Current Temperature 0x05 0x010 1 38 N-- Average Short Term Temperature 0x05 0x018 1 37 N-- Average Long Term Temperature 0x05 0x020 1 47 --- Highest Temperature 0x05 0x028 1 17 --- Lowest Temperature 0x05 0x030 1 43 N-- Highest Average Short Term Temperature 0x05 0x038 1 25 N-- Lowest Average Short Term Temperature 0x05 0x040 1 42 N-- Highest Average Long Term Temperature 0x05 0x048 1 25 N-- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 60 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 397 --- Number of Hardware Resets 0x06 0x010 4 213 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0009 2 5 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 6 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS
