LIGISTX
- Apr 12, 2015
Hi everyone,
Woke up this morning to a email alert of "Device: /dev/da3 [SAT], Self-Test Log error count increased from 0 to 1."
Doing a smartctl -x I get:
I think what I am seeing is it had a read failure via "# 1 Extended offline Completed: read failure 60% 37549"
What should next steps be? Try a resilver and long test after that? Just do a long test and see what it tells me? I love the SMART *usually* helps give warning of impending doom, I just wish I better understood what it was telling me...
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p12 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68N32N0 Serial Number: WD-WCC7XXXXXXXX LU WWN Device Id: 5 0014ee 20f3c6421 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Mar 20 08:22:03 2022 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 118) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (45180) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 480) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0 3 Spin_Up_Time POS--K 189 157 021 - 5533 4 Start_Stop_Count -O--CK 100 100 000 - 180 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 049 049 000 - 37554 10 Spin_Retry_Count -O--CK 100 100 000 - 0 11 Calibration_Retry_Count -O--CK 100 100 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 173 192 Power-Off_Retract_Count -O--CK 200 200 000 - 167 193 Load_Cycle_Count -O--CK 200 200 000 - 101 194 Temperature_Celsius -O---K 119 102 000 - 31 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 100 253 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 2 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb6 GPL,SL VS 1 Device vendor specific log 0xb7 GPL,SL VS 56 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 60% 37549 2088848576 # 2 Short offline Completed without error 00% 37522 - # 3 Short offline Completed without error 00% 37499 - # 4 Short offline Completed without error 00% 37475 - # 5 Extended offline Completed without error 00% 37459 - # 6 Short offline Completed without error 00% 37427 - # 7 Short offline Completed without error 00% 37403 - # 8 Extended offline Completed without error 00% 37388 - # 9 Short offline Completed without error 00% 37356 - #10 Short offline Completed without error 00% 37332 - #11 Short offline Completed without error 00% 37308 - #12 Extended offline Completed without error 00% 37292 - #13 Short offline Completed without error 00% 37261 - #14 Short offline Completed without error 00% 37236 - #15 Extended offline Completed without error 00% 37221 - #16 Short offline Completed without error 00% 37188 - #17 Short offline Completed without error 00% 37164 - #18 Short offline Completed without error 00% 37140 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) Device State: Active (0) Current Temperature: 31 Celsius Power Cycle Min/Max Temperature: 26/34 Celsius Lifetime Min/Max Temperature: 20/48 Celsius Under/Over Temperature Limit Count: 0/0 Vendor specific: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/65 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (73) Index Estimated Time Temperature Celsius 74 2022-03-20 00:25 32 ************* ... ..(163 skipped). .. ************* 238 2022-03-20 03:09 32 ************* 239 2022-03-20 03:10 31 ************ ... ..( 99 skipped). .. ************ 339 2022-03-20 04:50 31 ************ 340 2022-03-20 04:51 33 ************** ... ..( 12 skipped). .. ************** 353 2022-03-20 05:04 33 ************** 354 2022-03-20 05:05 34 *************** ... ..(152 skipped). .. *************** 29 2022-03-20 07:38 34 *************** 30 2022-03-20 07:39 33 ************** ... ..( 31 skipped). .. ************** 62 2022-03-20 08:11 33 ************** 63 2022-03-20 08:12 32 ************* ... ..( 9 skipped). .. ************* 73 2022-03-20 08:22 32 ************* SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 173 --- Lifetime Power-On Resets 0x01 0x010 4 37554 --- Power-on Hours 0x01 0x018 6 73271643701 --- Logical Sectors Written 0x01 0x020 6 1905247108 --- Number of Write Commands 0x01 0x028 6 555319278639 --- Logical Sectors Read 0x01 0x030 6 3556530456 --- Number of Read Commands 0x01 0x038 6 2050413824 --- Date and Time TimeStamp 0x03 ===== = = === == Rotating Media Statistics (rev 1) == 0x03 0x008 4 37362 --- Spindle Motor Power-on Hours 0x03 0x010 4 37260 --- Head Flying Hours 0x03 0x018 4 269 --- Head Load Events 0x03 0x020 4 0 --- Number of Reallocated Logical Sectors 0x03 0x028 4 284578 --- Read Recovery Attempts 0x03 0x030 4 0 --- Number of Mechanical Start Failures 0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors 0x03 0x040 4 167 --- Number of High Priority Unload Events 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 1 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 31 --- Current Temperature 0x05 0x010 1 32 --- Average Short Term Temperature 0x05 0x018 1 29 --- Average Long Term Temperature 0x05 0x020 1 48 --- Highest Temperature 0x05 0x028 1 20 --- Lowest Temperature 0x05 0x030 1 44 --- Highest Average Short Term Temperature 0x05 0x038 1 24 --- Lowest Average Short Term Temperature 0x05 0x040 1 37 --- Highest Average Long Term Temperature 0x05 0x048 1 27 --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 65 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 1470 --- Number of Hardware Resets 0x06 0x010 4 31 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 1 Transition from
