Trying to set up my first Scale cluster
morganL
Captain Morgan
Administrator
RC1.2 is available and should resolve this issue. Please confirm.
For me, it removed the not iterable error... unfortunately for me it's on to another one... some problem with resolving hostnames which seems to come after the datasets are created on each host... strange since it's all done via IP addresses up to that point.
JonathanTX
so far the issue reported looks clear!
now its on to figuring out more about scale! thank you!
morganL
Captain Morgan
Administrator
Hmmm... could you write up the issue Thanks.
There's probably a way we are doing it that may not be properly documented.
Even so, we shouldn't allow these types of issues to exist.
JonathanTX
speaking of documentation.... now that i have a cluster successfully set up, is there a place i can read about how to share out to other systems on the network?
morganL
Captain Morgan
Administrator
That's still Work In Progress.
The current mechanism is via Gluster clients. You can mount the clustered volumes as indicated here: https://www.truenas.com/docs/truecommand/clustering/mountingclustervolumes/
This is for linux clients.
The next mechanism will be via clustered SMB. The software and APIs for that are in SCALE RC-1.2, but the UI will be in TrueCommand during Q1-22
sophware
morganL
Captain Morgan
Administrator
The arbiter node function is temporarily disabled in the TrueCommand UI while its is being tested for stability. It should still be in the API.
Dispersed with 2 +1 is the current recommendation.
sophware
Thank you. If I have dispersed set up with 3 bricks/nodes, is that automatically 2+1?
