Going back to 11.3-U5 after upgrade the pool, is it possible ? Or there were not upgrades on 12 ?Yeah, i was also wondering if it was on track for release this week but then i saw this:
Reddit - Please wait for verification
www.reddit.com
A silent corruption bug doesn't seem fun, so i have the SMB bug with macOS clients & potentially a silent corruption storage system, so, maybe IX would suggest us to go back to 11.3-U5 & wait for atleast 12.0-U2? Currently it doesn't seem to be safe running on any 12-train?
After upgrade of the pool - no.Going back to 11.3-U5 after upgrade the pool, is it possible ?
[2021/01/16 16:44:27.197702, 0] ../../lib/util/fault.c:79(fault_report)
[2021/01/16 16:44:27.197795, 0] ../../lib/util/fault.c:80(fault_report)
INTERNAL ERROR: Signal 10 in pid 3270 (4.12.9)
If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see htt
ps://wiki.samba.org/index.php/Bug_Reporting
[2021/01/16 16:44:27.197892, 0] ../../lib/util/fault.c:86(fault_report)
[2021/01/16 16:44:27.197954, 0] ../../source3/lib/util.c:830(smb_panic_s3)
PANIC (pid 3270): internal error
[2021/01/16 16:44:27.200466, 0] ../../lib/util/fault.c:265(log_stack_trace)
BACKTRACE: 6 stack frames:
#0 0x801952d17 <log_stack_trace+0x37> at /usr/local/lib/samba4/libsamba-util.so.0
#1 0x802ccfb86 <smb_panic_s3+0x56> at /usr/local/lib/samba4/libsmbconf.so.0
#2 0x801952b07 <smb_panic+0x17> at /usr/local/lib/samba4/libsamba-util.so.0
#3 0x801952eee <log_stack_trace+0x20e> at /usr/local/lib/samba4/libsamba-util.so.0
#4 0x801952ae9 <fault_setup+0x59> at /usr/local/lib/samba4/libsamba-util.so.0
#5 0x80fd48c20 <_pthread_sigmask+0x530> at /lib/libthr.so.3
[2021/01/16 16:44:27.200798, 0] ../../source3/lib/dumpcore.c:315(dump_core)
dumping core in /var/db/system/cores
Too early. Still crashing ... three concurrent backups (approx 500GB each)
All windows 10 clients seem to genarate insanely traffic while simply browsing the smb shares
This happened to me just now after a fresh TrueNAS 12.0-U1.1 start, and Explorer crashed. After restarting Explorer, browsing was fast, and ARC use had grown to 20 GiB.
I'd say it has to do with fetching metadata. Give your TrueNAS enough RAM for ARC, that might just solve it. I had 32 GiB in this TrueNAS server and now increased it to 64 GiB. What are you running with?
nas 1 2021-01-17T14:09:19.315783+01:00 nas.net.lan mountd 1546 - - can't open /etc/zfs/exports nas 1 2021-01-17T14:09:19.316993+01:00 nas.net.lan mountd 1546 - - can't open /etc/zfs/exports
...silent data corruption seems to be exclusively linked with VMs under certain (rather special) circumstances...
