SOLVED Truenas U1.1 fix schedule > waiting for U2 !
Kris Moore
SVP of Engineering
Administrator
We're looking at early next week, but waiting on a review for a couple performance related fixes still. Will known for sure in next day or so.
headwhacker
Is U1.1 on track for release this week?
JesperA
Yeah, i was also wondering if it was on track for release this week but then i saw this:
A silent corruption bug doesn't seem fun, so i have the SMB bug with macOS clients & potentially a silent corruption storage system, so, maybe IX would suggest us to go back to 11.3-U5 & wait for atleast 12.0-U2? Currently it doesn't seem to be safe running on any 12-train?
andrema2
Going back to 11.3-U5 after upgrade the pool, is it possible ? Or there were not upgrades on 12 ?
Patrick M. Hausen
awasb
Since the silent data corruption seems to be exclusively linked with VMs under certain (rather special) circumstances and the arbitrary smb crashing with macOS clients just occurred with 12.0-U1, I switched back to 12.0-RELEASE and everything seems fine so far (the reporting bugs aside). Not much effort, just a reboot. "My" users are happy.
*coughing* "Move along, there is nothing to see here." *coughing*
Concerning the "silent" data corruption, is it implied that not even a Scrub will detect corrupted blocks / data?
tiberiusQ
I do run 12U1 and beside the know issues I do experience a new strange behaviour-
All windows 10 clients seem to genarate insanely traffic while simply browsing the smb shares- Is this a known issue with this Truenas version or a new Windows feature ?
ref.
awasb
It's out and — as far as first stress tests show — the smb seg faults are seemed to be gone.
THX!
awasb
Too early. Still crashing ... three concurrent backups (approx 500GB each)
$ tail -f /var/log/samba4/log.smbd
[2021/01/16 16:44:27.197702, 0] ../../lib/util/fault.c:79(fault_report)
[2021/01/16 16:44:27.197795, 0] ../../lib/util/fault.c:80(fault_report)
INTERNAL ERROR: Signal 10 in pid 3270 (4.12.9)
If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see htt
ps://wiki.samba.org/index.php/Bug_Reporting
[2021/01/16 16:44:27.197892, 0] ../../lib/util/fault.c:86(fault_report)
[2021/01/16 16:44:27.197954, 0] ../../source3/lib/util.c:830(smb_panic_s3)
PANIC (pid 3270): internal error
[2021/01/16 16:44:27.200466, 0] ../../lib/util/fault.c:265(log_stack_trace)
BACKTRACE: 6 stack frames:
#0 0x801952d17 <log_stack_trace+0x37> at /usr/local/lib/samba4/libsamba-util.so.0
#1 0x802ccfb86 <smb_panic_s3+0x56> at /usr/local/lib/samba4/libsmbconf.so.0
#2 0x801952b07 <smb_panic+0x17> at /usr/local/lib/samba4/libsamba-util.so.0
#3 0x801952eee <log_stack_trace+0x20e> at /usr/local/lib/samba4/libsamba-util.so.0
#4 0x801952ae9 <fault_setup+0x59> at /usr/local/lib/samba4/libsamba-util.so.0
#5 0x80fd48c20 <_pthread_sigmask+0x530> at /lib/libthr.so.3
[2021/01/16 16:44:27.200798, 0] ../../source3/lib/dumpcore.c:315(dump_core)
dumping core in /var/db/system/cores
Rolling back to TN12.0 RELEASE.
djjaeger82
Samba fix was not in u1.1, it was pushed to U2 since the data corruption fix was prioritized for U1.1. Be very careful running 12.0 or 12.0u1. For the data corruption severe issue I'd either roll back to 11.3 or keep 12.0u1.1 with the samba bug
Yorick
This happened to me just now after a fresh TrueNAS 12.0-U1.1 start, and Explorer crashed. After restarting Explorer, browsing was fast, and ARC use had grown to 20 GiB.
I'd say it has to do with fetching metadata. Give your TrueNAS enough RAM for ARC, that might just solve it. I had 32 GiB in this TrueNAS server and now increased it to 64 GiB. What are you running with?
awasb
@ djjaeger82: Tanks for the hint. Still ... I don't run any virtual instances on TrueNAS, so the data corruption bug in ZFS (as far as I know and understand it, that is) isn't an issue for me/us.
tiberiusQ
Ahh - In this box I do also have 32gb ram, I may do uprade to 64 as well....
gwaitsi
Still hasn't solved the issue of:
nas 1 2021-01-17T14:09:19.315783+01:00 nas.net.lan mountd 1546 - - can't open /etc/zfs/exports
nas 1 2021-01-17T14:09:19.316993+01:00 nas.net.lan mountd 1546 - - can't open /etc/zfs/exports
These errors are triggered by the jails mounted drives and only started appearing after upgrading from 11.5 to 12.0
CHL
...silent data corruption seems to be exclusively linked with VMs under certain (rather special) circumstances...
is there some more information about this out there? how to know when I may run into this BEFORE it happens? :smile: data corruption on zfs was never worth a thought... up to now?
Update to U1.1 and render that discussion a lot less relevant.
