Truenas randomly shutting down
Samuel Tai
Yeah, that looks like some sort of protection circuitry kicking in, and cutting power to the board.
What are the exact models of the Seagates and HGSTs for disks da14-20? This could be one of your Icy Docks is pulling too much power.
NugentS
SMR or CMR?
PlasmPlayer
Here are i believe all the modelss
Seagate ST500LM021-1KJ15 - 7200 RPM
Seagate ST500LT012-1DG14 - 5400 RPM
HGST HTS545050A7 - 5400 RPM
HGST HTS725050A7 - 7200 RPM
WDC WD5000LPLX-6 - 7200 RPM
Samuel Tai
PlasmPlayer
It's going to suck if it is the IcyDock Drive Bay causing problems. That is what this server was built around. Is there a way to tell which one is causing problems? i can try to warranty it
Samuel Tai
Whichever one is hosting da14-da20.
PlasmPlayer
Sounds good. Does truenas keep the same drive names after each reboot? I keep a spreadsheet of where each drive serial number is located.
Samuel Tai
No, drive devices aren't guaranteed to be stable. Look in the GUI, under Storage->Drives for the relevant serial numbers.
PlasmPlayer
thats going to make it difficult to figure out which one is causing issues. I might open up the chassis and reseat everything in case a cable is not fully seated.
NugentS
According to Seagate's website all their 2.5" drives are SMR
The WD might be SMR (50:50)
The HGST are probably DM-SMR (maybe)
I think we can safely say its highly unclear - but not looking good
[I would really love to be wrong on this]
PlasmPlayer
well that sucks, just about all of them are seagate. could that cause these errors from the video and causing the system to shut down?
PlasmPlayer
Did a little google fu and it looks like the seagate thin drives are part of the momentus line and are perpendicular drives which is the same as CMR
This is pretty useful information. but this leaves the question if its the hard drive encloser causing the timeouts.
I am learning a lot about hard drives and hardware today
pschatz100
There have been lots of good comments here. I would also like to add that gaming boards have lots of features not compatible with TrueNAS and you should turn them all off in the bios: audio, enhanced networking features, any overclocking or system tuning, etc. For good measure, I would also temporarily disable all power-saving features. If the system runs better, then you know something was causing a conflict.
jgreco
Resident Grinch
and 2 HBA cards connecting up to 32 2.5 inch hard drives.
While 2.5" drives aren't as hard on a PSU as 3.5" are, you're still potentially short. If you'd like to learn how to properly design a PSU for NAS, please look at
PlasmPlayer
I tried this calculator here
with 32 drives and the 3 SSDs, it says the recommended PSU size should be 331 Watts
The datasheet for the Seagate drives says the peak power draw when starting up is 5 watts and run at usually just under 2 watts
jgreco
Resident Grinch
Generic PC power supply calculators generally do not make proper allowance for spinup current. 5 watts times 32 drives is 160 watts all on its own, so clearly that's full of crap. Please go back and look at the post I pointed you at, which will teach you the correct way to calculate this and ALSO explains WHY it is the correct way to calculate it.
PlasmPlayer
I read through a bit of that post and information from 45 drives.
So I'm guessing I should upgrade to a 1000 watt PSU? If so, I was looking at the Seasonic PRIME GX-1000
Samuel Tai
It's not just the power headroom on the PSU you need to look at, but also the amp delivery on the rails.
Samuel Tai
Your CPU is way overkill for this application. In fact, you could swap your i7-4790K (88W TDP) for an i5-4460T (35W TDP) and still have lots of CPU in reserve for jails and VMs. Disable your audio system and any automatic overclocks to gain additional power headroom.
PlasmPlayer
The 12v rail can support 996 watts.
The 4790k is left over after upgrading my main computer. I plan on getting a e3-1240l v5 setup when funds are available. 25watt CPU with also 8 threads. Should be more than enough for my needs
