In my opinion, if you care about your data, intend for the NAS to be up 24x365, last for >4 years, then ECC is highly recommended.
ZFS is like any other file systems, send corrupt data to the disks, and you have corruption that can't be fixed. People say "But, wait, I can FSCK my EXT3 file system". Sure you can, and it will likeky remove the corruption and any data associated with that corruption. That's data loss.
However, with ZFS you can't "fix" a corrupt pool. It has to be rebuilt from scratch, and likely restored from backups. So, some people consider that too extreme and use ECC. Or don't use ZFS.
All that said. ZFS does do something that other file systems don't. In addition to any redundancy, (RAID-Zx or Mirroring), ZFS stores 2 copies of metadata and 3 copies of critical metadata. That means if 1 block of metadata is both corrupt AND that ZFS can detect that corruption, (no certainty), ZFS will use another copy of metadata. Then fix the broken metadata block(s).
