I read through the (Locked Ecc discussion) but found people skating around the question. They usually just say use ECC end of story.
I would like to see real world numbers on the risks. Many people have old perfectly good (Non ECC) computers laying around that would make a nice home NAS. So rather than dump it in the trash they can make it useful. I fully realize ECC is the best way to go.
Are you saying that if you do not have ECC ram and wanted to set up a RAID 1 freenas one should only use UFS?
1. Single Hard drive SATA - risk of corruption?
2. Raid 1 - non ECC ZFS risk "
3. Raid 1 non ECC UFS
4. Raid 1 Dell Perc 6i?
5. Raid 1 ECC + ZFS ?
I have 5 NAS that I built.
Two of them have ECC and quad Xeons with 8 gig (Dell 490s)
Two of them are non ECC ZFS raid 1 with 1 8 gig stick
one is a UFS non ECC.
They are running 24/7 with no UPS for 4 years or so. They have had power outages, abrupt shutdowns and all sorts of bad things.
So far - zero bad scrubs, zero bad files, they all working like new.
I use them all for backups but I don't copy to one then take that copy and move to the others. The copy is from my PC. I also have USB3 drives I keep in a fireproof box as a 6th backup. Again I don't copy from one NAS to another so no chance for them to spread corruption unless my original was bad to begin with.
Maybe using raid 5 uses more ram and thus might potentially induce more errors than raid 1 ZFS.
How does one prove that a memory issue caused a non mounting pool vs other reasons?
Should I change my non ECC zfs NAS boxes to UFS?
Is there any real proof that UFS +non ECC is ?X more reliable vs ZFS + non ECC?
Of course sun would recommend ECC in enterprise situations, almost every computer in business enviroments use ECC non matter if they use ZFS or not.
Does ZFS + non ECC offer anything over UFS + non ECC?
If not then just make it simple. In the ZFS setup of nas4free or Freenas put a big RED warning pop up when someone attempts to make a ZFS pool. "DO YOU HAVE ECC RAM? if not please select UFS file system for you raid.
Just seems to be a bit of a religious fear type mongering going on here on the topic of ECC.
