So i have been contemplating the truenas mini X appliance but some online reviews are reporting noise levels around 38 dbA. While that is not loud by normal server standards, it might prove to be distracting in a quiet office environment.
I was thinking that, if i can increase the airflow by adding another fan, then the rest of the fans could spin slower which will lower the noise levels. It appears that the best implementation would be to put a fan right behind the hard drive cage which would also help extract the heat that gets trapped between the drives.
Does this make sense? or am I overthinking this?
Also, does anybody know how the noise levels of this unit compares to something like HPE ML30 Gen10?
