TrueNAS CORE/Enterprise 12.0-U5.1 Released
Kris Moore
SVP of Engineering
Administrator
Heads up, that a minor update to TrueNAS 12.0-U5.1 went out today. This is a hot-fix release which improves some performance of the middleware and user-interface for systems with large disk counts. As always we appreciate feedback, and happy updating!
Upgraded three systems remotely via VPN. I like to live dangerously.
Patrick M. Hausen
Keeping up with the tradition of a .1 release for every single update in the 12.0 train, I see :wink:
Seriously, I appreciate the work. Thanks.
ThreeDee
Upgraded without a hitch .. appreciate your guys' efforts!
kspare
Is this to fix the mem leak?
morganL
Captain Morgan
Administrator
The mem leak and python crash issue was resolved in U5.
U5.1 resolved some UI performance issues when managing more drives.
It was low risk and provided significant benefits to some larger users.
kspare
is it normal that under 12 I run 64 gb of ram under services and order 11.5 I run 2? System is used for nfs only
morganL
Captain Morgan
Administrator
Can you be more clear and document what the system is saying about RAM. Most RAM is used for ARC .. is there something else hogging it?
inman.turbo
ric2498
FYI, just updated from TrueNAS 12.0-U5 to TrueNAS 12.0-U5.1; everything is working well except lost the DISK details into the panel Storage / Disks ????, ... No data to display.
Same result on 2 servers running under VMware 6.5
Forza
I had one issue after upgrade from 5.0 to 5.1. Handling of NFS permissions is slightly diffferent, which caused some clients unable to connect. Had to change my permissions setup slightly to regain NFS access.
pschatz100
Updated from TrueNAS 12.0-U2 to TrueNAS 12.0-U5.1. No problems.
HannesM
Updated from TrueNAS 12.5 to 12.0-U5.1 is the return of the VM startup error (Debian 10.9 VMs).
any idea what happend ? difference from 12.5 to 12.5.1 ?
regards
Hannes
kspare
one system is idle the other is in use...I haven upgraded to u5.1 waiting for the bugs to be ironed out...
morganL
Captain Morgan
Administrator
That is most of 1TB of RAM being consumed.. wow.
It must be a bug... can you report a bug with debugs and the list of services being used.
