Mellanox card will work for new TrueNAS Scale server?
Mellanox ConnectX-5 Dual Port 100GbE - MCX516A-CDAT
I assume this would be supported out of the box with the mlx5en driver?
This is a PCIe Gen4 card so it should provide enough bandwidth from one PCIe slot to support the full 200 GB of theoretical bandwidth.
The problem with the Gen3 Dual port cards is most of them will not support enabling both ports and getting the full bandwidth.
Right now I have 100gb QFSP+ ports on my switch and will be using fiber to connect.
Is it better to buy two one port 100gb cards instead of one with dual-ports?
Is there a better PCIe Gen4 supported card I should look for?
