I just successfully added the Broadcom 9600-24i card connected to ICY Dock MB699VP-B V3 Mobile Rack via (2) OCuLink cables on my Dell T7920 TrueNAS system running TrueNAS-SCALE-24.04-BETA.1. I am trying to build an All-Flash NVME U.2 TrueNAS system that is quiet, reasonably fast, and “economical”, made mostly of spare parts that I already have. Under this configuration, each drive is getting PCIe 3.0 x 4 NVMe bandwidth, accommodating drives up to 15mm in height. Unfortunately I am limited by PCIe 3.0 speeds on my older Dell T7920 system. I have up to (5) available PCIe 3.0 slots on this Dual CPU system for HBA cards, allowing up to a theoretical maximum of 20 U.2 drives (if using 9500-16i cards) or 24 (if using 9600-24i cards), again each drive at PCIe 3.0 x 4. These cards do not use a PCIe “switch” like the P411W-32P cards. Obviously, these additional ICY Dock Mobile Racks would require a separate external 5.25 inch enclosure given the limited space of the Dell T7920 workstation. In my current setup, I have one ICY Dock mobile rack up front in the 5.25 slot and a second mobile rack in back lower part of the case, just below the power supply. Mounting mobile racks in the Dell case required some ingenuity, including 3M red double sided foam sticky tape and adhesive plastic shims. 3d printing a mounting structure may help in the back of the case.
At this point in time, we are somewhat limited in separate NVME backplane offerings since the UBM (Universal Backplane Management) standard by Broadcom is starting to take hold.
An alternative enclosure includes the Serial Cables enclosures as seen on recent Storage review article and YouTube video, website https://www.serialcables.com/.
https://www.storagereview.com/review/broadcom-megaraid-9670w-16i-raid-card-review
Supermicro also has some NVME backplanes that can be added to their rack servers. One such example is the SYS-220U-TNR server that Storage Review did a short video on.
https://www.youtube.com/watch?v=2kjtBvOYj6s
Lastly, 45 Drives is coming out with an All-Flash Stornado F2 server. They are using the Broadcom 9600-16i card in their current F2 Stornado and offer the server in both Intel and AMD variants. The AMD cpus can offer high count PCIe lanes with just one CPU.
https://www.45drives.com/products/nvme.php.
It will also be interesting to see some coming reviews of the iX systems upcoming F100 All-Flash TrueNAS server which runs TrueNAS Scale.
Compared to my other rack servers, this setup is very “quiet”, currently sitting in my office. With the ICY Dock fan speed to low (middle setting), the NVME drives remain relatively cool or slightly warm to the touch. The 9600-24i card however is running a bit hot and will likely require some additional cooling, possibly an additional small Noctua fan.
The Dell T7920 uses a 1400W power supply which provides adequate power for the (2) additional mobile rack units. Additional units may require extra external enclosure power supply.
Although the system is running well overall, I am unable to get the 9600-24i to post to BIOS like I am able to do with the 9500-16i cards. Fortunately, this is not necessary with the TrueNAS system. I tried changing the Dell UEFI and Legacy bios settings with no luck. Is this typical of the Broadcom 9600 HBA series? Is there a card option I can turn on or off? The card also works well with Windows 11 Pro. As a result of not posting to bios, I cannot boot off any disks attached to the 9600-24i card. The card otherwise loads well with the included Beta Dragonfish driver.
Although the 9600-24i card adds an additional SlimSAS connection for a total of 3 ×8 SFF-8654 ports, the peak speeds on this card (roughly 2000MB/sec write and 2000 MB/sec read on single drive in non-redundant stripe mode) are very similar to the 9500-16i card, which has (2) SlimSAS ports. Given the similar speeds (on PCIe 3.0 system at least) and large price differential (9600-24i $936.99 vs 9500-16i $340 on Amazon), it’s probably best to just use the cheaper 9500-16i in your build with multiple HBA cards. I am not sure how much speeds will improve on a PCIe 4.0 system.
Since Broadcom HBA cards do not offer any hardware RAID functionality, I don’t think there is a separate “IT firmware version” of these cards as they are already HBA only cards. BIOS is current on both cards.
I also have the P411W-32P card (somewhat dated last firmware update of 6/6/2021), which has already been documented to not work with the ICY Mobile Rack. I had the same experience. As mentioned in another post, do not flash this card with custom firmware provided by ICY Dock as another member of this forum bricked his card.
Lastly, I will also be testing the 9600-16i card in a week or two pending delivery.
By the way, be careful to buy only authentic Broadcom versions of these cards as there are a lot of cheap Chinese counterfeit “Broadcom” cards on Ebay which look almost exactly the same as the authentic card but can have firmware and other hardware limitations. The Art of the Server YouTube channel has several videos on this subject.
So far TrueNAS Dragonfish Beta 1 is super stable with no instability or detectable bugs so far.
“TrueNAS SCALE has inherited the storage functionality and automated testing from CORE. SCALE has matured rapidly and offers a more robust apps environment based on Linux Containers & KVM. TrueNAS SCALE is generally recommended for new users that need embedded apps, and will gradually become the recommended version for all new TrueNAS users.” As mentioned above, the iX Systems All-Flash F100 server will run on TrueNAS Scale.
https://www.truenas.com/blog/truenas-scale-dragonfish/
iX Systems and the Debian Linux development team did a great job with this release.
I will update this post as I continue to test and use this system.
Thanks,
Rich
My test system:
Dell 7920 Firmware 2.38.0 (Current)
Dual CPU Intel Xeon Gold 6258R @ 2.70GHz (2nd CPU adds 2 additional PCIe 3.0 x 16 slots).
512 MB Ram - NEMIX RAM 512GB (8X64GB) DDR4-3200 PC4-25600 ECC RDIMM Registered Server Memory Upgrade for Dell PowerEdge T550 Tower
(1) Mellanox MCX613106A-VDAT 200GbE Card, plugged into PCI slot #1, connected at 100GbE to Arista Switch
(2) Broadcom 9500-16i, slots #6 and #7
(1) Broadcom 9600-24i, slot #2
(4) DiliVing SlimSAS 8X to 2*oCulink 4X,SFF-8654 74pin to 2*SFF-8611 36pin Cable 80cm(Broadcom MPN 05-60001-00)
(2) ICY DOCK 4 x 2.5 NVMe U.2/U.3 SSD PCIe 4.0 Mobile Rack for 5.25" Bay with OCuLink | ToughArmor MB699VP-B V3
(2) U.2 NVME SSD Hard Drive Expansion Interface Backplane Kit Compatible with Dell Precision 7920 T7920 Tower Workstation 076W3N
(1)M.2 SAS Flex Bay Module Compatible with Dell Precision T5820 T5820XL T7820 T7820XL T7920 T7920XL 066XHV 66XHV w/Tray Without SSD only for M Key 2280 M.2 NVMe (PCIe Gen3 x4) SSD
(1) SAMSUNG 980 PRO SSD 2TB PCIe NVMe Gen 4 Gaming M.2 Internal Solid State Drive Memory Card MZ-V8P2T0B/AM (TrueNAS is installed on this M.2 drive.)
(4) Intel D5-P4326 Series 15.36TB U.2 NVMe/PCIe 2.5" QLC SSD Solid State Drive
(2) SOLIDIGM D5-P5336 30.72 TB Solid State Drive - 2.5" Internal - U.2 (PCI Express NVMe 4.0 x4) - Server Device Supported - 0.56 DWPD - 3000 MB/s Maximum Read Transfer Rate
Video Card VisionTek Radeon RX550 4GB GDDR5 (Plugged in the small PCIE Gen 3 x8 open ended slot #5 as I only need minimal video ability to view TrueNAS startup text and IP address.
As mentioned above, this system setup allows for a maximum of (5) Broadcom HBA cards.
Thanks,
Rich
My test system:
