TrueNAS-12.0-U1.1 SMB cant conenct
sojab0on
Hi ,
I just installed TrueNAS-12.0-U1.1 on my custom server witch ran proxmox before.
System Specs
7 drive
1 PNY Optima 240GB SSD (Boot Drive)
2 2TB HDDs setup as pool
4 3TB drives (will be the pool for a data storage NAS VM)
CPU : E5-2670v1 8 Core 16Tread
RAM 64 GB DDR3 ECC
Motherboard Asrock X79 Extreme11
Dual Broadcom GB nic onboard
I setup the SMB service and set the drivepool as share but i cant conenct windows wont let me
Added SMB share settings
Client
Windows 10 Pro 20H2 fully updated firewall off same for AV from mafee (just for testing)
Can some one please point me where i did something wrong
sojab0on
I have desided to rebuild the system, i can normally have a vm running or shutit down also
so i am turrning away from truenas/freenas
sojab0on
get this error on every shutdown or reset trough gui, only way to get it working is rebooting the full server
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
await self.future
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1585, in stop
vm.stop(vm_data['shutdown_timeout'])
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 252, in stop
self.domain.shutdown()
File "/usr/local/lib/python3.8/site-packages/libvirt.py", line 2659, in shutdown
if ret == -1: raise libvirtError ('virDomainShutdown() failed', dom=self)
libvirt.libvirtError: An error occurred, but the cause is unknown
