Transmission watch folder
Tito
So, I don't know what I need to do differently. But when I add files to the watch folder Transmission doesn't pick them up. I am able to download through transmission, but I have to add the files manually.
I've included a picture of the options under the plug-in drop down on the left. In all the posts about transmission I've seen they have different options.
All I want is for transmission to automatically pick up files in the watch folder.
Yatti420
Whats with the exclamation marks? I use /tmp and any .torrent placed in there is picked up by transmission..
Tito
It's the simply the top character in alphabetical order. Just puts the folder at the top so I can see it more easily in Windows. I've change the naming, still doesn't catch files in the watch directory.
Jeremy Foor
I've had the same issue. Might be a permissions thing. I had to manually edit settings.json in the transmission config folder within the jail. Changing it from the webgui did nothing or at least didn't save.
BlackRugger
Jeremy how do you edit the settings.json file, I am new to manually completing setups.
