monkeybutt
- Dec 10, 2016
I am having trouble getting permissions setup probably with Transmission and Sonarr. I have been messing with it for a while so I am in the middle of a chicken and egg type scenario at the moment. Long story short, when I first setup Transmission, I got it so files would download with full read/write/execute permissions so I could access and delete as needed from a network folder. An example of file permissions are like so:
Then I installed Sonarr, and the first file I tried to download ended up getting an error "Sonarr: No files found are eligible for import in /filepath/" which made me think it was a permission issue with Sonarr.
I went to check the downloaded file's permissions and they were:
Now even files that I manually add to Transmission come back with only read/write permissions. I have no idea where to go from here.
I found this guide https://forums.freenas.org/index.ph...plugins-write-permissions-to-your-data.27273/ which I figured would solve my problem, but the changes I made seemed to make no difference. I have no idea why the new files I download are not getting full read/write/execute permissions.
Any ideas?
EDIT: I have it manually set for Transmission files to download as 777, and umask is definitely set to "0" in settings.json. Something else seems to be interfering.
33 drwxrwxrwx 2 root wheel 8 Dec 19 08:37
32257 -rw-rw-rw- 1 921 wheel 1513308160 Dec 19 18:18
Any ideas?
