Time Machine
csearle
hey guys I just recently got this issue with time machine Im hopping someone can help me
Time Machine could not delete the backup disk image “/Volumes/com.apple.TimeMachine.TimeMachine-7FC17663-B9DB-4787-80D9-2B9D00D2BF17/Sir3lly's MacBook Pro.sparsebundle”.
csearle
this message is from macOS
not sure how to check my versions for AFP
csearle
macOS is 10.14.5 and NAS 11.2
csearle
Yes I do I even set up a new user for this operation
csearle
So I got into the time machine directory, that second line though that's a harder one to crack. Please help
anodos
Sambassador
ls -l there will probably give enough information. I primarily need to see the posix mode and owner. FYI, shell supports tab-completion so you can type getfacl and space and then hit tab twice to see available options. Once you do that you can type the first letter of the file and hit tab, and the rest should autocomplete (unless there is more than one option - in this case, press tab twice to see what the options are).
csearle
phew this is what I got with the ls -l comand
-rwxrwxrwx 1 csearle csearle 0 Apr 10 23:37 .apple
drwxr-xr-x 2 root csearle 9 Jun 24 18:38 .AppleDB
-rw-r--r-- 1 admin csearle 6148 Jun 22 21:19 .DS_Store
drwxr-xr-x 3 csearle csearle 5 Apr 14 13:58 Sir3lly's MacBook Pro.purgeable.sparsebundle
drwxr-xr-x 3 csearle csearle 10 Jun 18 20:38 Sir3lly's MacBook Pro.sparsebundle
drwxr-xr-x 2 timemach timemach 10 Jun 22 21:22 timemach
and this is what I get with hitting the space and tab
.apple
.AppleDB/
.DS_Store
Sir3lly's MacBook Pro.purgeable.sparsebundle/
Sir3lly's MacBook Pro.sparsebundle/
timemach/
seanm
So from the same directory that you ran the 'ls -l' command, type:
getfacl Sir
then press the tab key. It should partially complete it to:
getfacl Sir3lly\'s\ MacBook\ Pro
then type ".sp" then tab again, then it should fill it out all the way.
csearle
Sorry Im Such a noob on this but here is the result
[root@SirNas /mnt/Candice/TimeMachine]# getfacl Sir3lly\'s\ MacBook\ Pro.sparsebundle/
# file: Sir3lly's MacBook Pro.sparsebundle/
# owner: csearle
# group: csearle
owner@:rwxp--aARWcCos:-------:allow
group@:r-x---a-R-c--s:-------:allow
everyone@:r-x---a-R-c--s:-------:allow
Thanks for helping me out.
seanm
googling "sparsebundle purgeable time machine" suggests the existence of the 2nd .sparsebundle with "purgeable" in the name means something went wrong. Whether it was FreeNAS or macOS's fault I dunno.
csearle
I tried to delete the Purgeable file and the system won't let me
csearle
@seanm would it be better if deleted the dataset and try again?
