Time Machine - OS X 10.7 Lion - 8.0.1 RC - AFP
tmacka88
Just upgraded to the new 8.0.1 RC firmware. I tried to configure time machine with Volume 2 of my freenas system, but I get this error once it trys to start the backup process.
Time Machine Error
"The network backup disk does not support the required AFP features."
Now I typed:
defaults write com.apple.systempreferences TMShowUnsupportedNetworkVolumes 2
into the mac terminal so I could see Volume 2 drive.
I selected this drive and tried to back up, it then gave me the error above.
Any ideas has anyone successfully got time machine working again with OS X 10.7 Lion and 8.0.1 RC.
Thanks
seggerman
Hi tmacka88,
I've used Build 8r7209 with a patch by Delphij (FreeNas developer) to successfully backup my wifes MB (10.7.1, around 80GB of data). Over the weekend I want to give the RC1 a shot, but concerning AFP nothing much has changed.
Since you mentioned that you had the change the defaults on OSX did you create the volume on FreeNAS as a Timemachine Volume and did you also check the "disk discovery" option for the AFP Share?
Cheers
Alexander
tmacka88
I just made it Volume 1, didn't use disk discovery. ill give it a try
S
sanctuarydan
Guest
Now I typed:
As I understand it the correct syntax is sudo defaults write com.apple.systempreferences TMShowUnsupportedNetworkVolumes 1
tmacka88
seggerman
This isn't necessary if everything is set up correctly on the FreeNAS side. The volume hast to be a setup as timemachine and "disk discovery" must be checked.
Alexander
garth
Alexander
This is important - the "TMShowUnsupportedNetworkVolumes" kludge means that the user did not setup FreeNAS properly and you will not be able to restore via Time Machine properly.
