paulinventome
- May 18, 2015
So new build, got two zpools, one is a ZRAID2 with 8x16TB drives and the other is a mirror with 2x4TB SSDs, server is running over 10gbe.
Tested from both a Mac and a Windows machine and with both pools and seeing the same, I get around 400MB-500MB/s writes and reads are around 1MB/s, yes 1. So something is up and I need some pointers to track down.
I am just running SMB service. CPU and the system barely registers the load. I am looking at the Reports side, if I look at the SSD for example I see the write maxing at 260MB/s (still think this is poor and I assume the external 400/500 I am seeing is because of RAM. But the report shows that the disk reads being tiny. Same for the ZRAID2 pool.
So I'm fairly new to this, where can I start troubleshooting? Are there any tools within TrueNAS UI that would let me check the disc performance locally as a first step? I am fairly happy with command lines too.
Does a 1MB/s read performance either off RAID or SSD ring any bells with anyone?
This is replacing an ageing Synology 3612xs which has been running 8 years, I still get 600MB/s to and from that. Same network, same clients, same testing software (Blackmagic Speed Test)
Any pointers would be really appreciated!
thanks
Paul
thanks
Paul
