Wizened Sage
- Aug 16, 2011
The drives are ada0-ada6 and da0-da7, so there are no double-digit drive numbers (if by that you mean that the N in adaN is two digits). My suspicion is that there are two unrelated things going on:It might have something to do with text-parsing double-digit drive numbers, but that's speculation.
- The temps of ada0 and ada1 are being parsed incorrectly (perhaps reported incorrectly), which ultimately leads to the error message I'm seeing
- The script is only scanning /dev/adaN for temperatures, not /dev/daN
for i in $(/sbin/sysctl -n kern.disks | awk '{for (i=NF; i!=0 ; i--) if(match($i, '/da/')) print $i }' );
and it works fine, except that ada0 and ada1 still give odd output. It looks like the same change could be made to temps-rrd-format.sh.
As to the first issue, it looks like the SATA DOMs have two attributes they're reporting (194 and 231) with the label of "Temperature_Celsius". Here's the SMART output of one of them:
[root@freenas2] /mnt/tank/scripts/freenas-temperature-graphing# smartctl -a /dev/ada0 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: KingSpec KDM-SA.71-016GMJ Serial Number: 985021000159 LU WWN Device Id: 5 000000 000000000 Firmware Version: 1.094.12 User Capacity: 16,013,942,784 bytes [16.0 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA >3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue Apr 19 13:03:23 2016 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 245) Self-test routine in progress... 50% of test remaining. Total time to complete Offline data collection: ( 32) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 1) minutes. SCT capabilities: (0x0039) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 0 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000a 100 100 000 Old_age Always - 0 2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0 3 Spin_Up_Time 0x0007 100 100 050 Pre-fail Always - 0 5 Reallocated_Sector_Ct 0x0013 100 100 050 Pre-fail Always - 0 7 Unknown_SSD_Attribute 0x000b 100 100 050 Pre-fail Always - 0 8 Unknown_SSD_Attribute 0x0005 100 100 050 Pre-fail Offline - 0 9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 9943 10 Unknown_SSD_Attribute 0x0013 100 100 050 Pre-fail Always - 0 12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 12 167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 0 168 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 3 169 Unknown_Attribute 0x0013 100 100 010 Pre-fail Always - 131073 170 Unknown_Attribute 0x0013 100 100 010 Pre-fail Always - 0 171 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 0 172 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 0 173 Unknown_Attribute 0x0012 001 001 000 Old_age Always - 4295229441 175 Program_Fail_Count_Chip 0x0013 100 100 010 Pre-fail Always - 0 180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 100 100 020 Pre-fail Always - 128 187 Reported_Uncorrect 0x0032 000 000 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 7 194 Temperature_Celsius 0x0022 075 075 030 Old_age Always - 25 (0 60 0 30 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 231 Temperature_Celsius 0x0033 100 100 005 Pre-fail Always - 0 240 Unknown_SSD_Attribute 0x0013 100 100 050 Pre-fail Always - 0 241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 27787834 242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 496520585 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Self-test routine in progress 00% 9943 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@freenas2] /mnt/tank/scripts/freenas-temperature-graphing#
