I'm running FreeNAS 11.1-U7 (likely 11.2-U7 or later by the time I get around to making changes) on a cheap 120GB HP S700 SSD. Now that the price of SSDs has dropped to about what decent flash drives used to cost, I was thinking it might not be a bad idea to mirror my boot SSD (which also contains the system dataset).
Is this easy to do? Do I have to reinstall FreeNAS from scratch, or can I just plug in a second SSD and do something (either from the command line or the GUI and turn a single disk pool into a mirrored pool?
I noticed that I can get a Lexar NS100 120GB SATA III (LNS100-120RBNA) really cheap - is there any reason not to pair it with the existing HP SSD S700 (2DP97AA#ABC)? Both drives are very mediocre performers, but IIUC high performace doesn't really matter. In 2 years running time based on the smart data, the existing S700 drive has about 4GB written, so endurance isn't a big deal either.
Any comments/suggestions are appreciated.
