Midshipman
- Apr 14, 2017
Greetings. I have a FreeNAS build running FreeNAS-11.2-U5 that I'm going to do a few upgrades to:
- Move all internals into a new case. (UNAS NSC-810A)
- Replace my boot drive. (Its currently a cheap USB memstick and I am upgrading to an HP SSD S700 Pro)
- Update FreeNAS to the current version.
- Replace my entire HDD set. (Its currently seven 3TB WD Greens with two parity shucked from external cases back in 2013 and I'm *most likely* moving to four 12TB Seagate Ironwolf Pro with one parity, or possibly 6 or 8 drive with two parity.)
- Per this thread it seems I don't need to worry about which ports on my Supermicro X10SL7-F motherboard I reconnect all of my drives to. Always good to get a confirmation though!
- What's the best way to move to a new boot drive and update? Save my config, fresh install current FreeNAS on new drive, load config? Or should I not mix step 2 and 3 above? Per boot section of manual it looks like I can Clone my system to the new drive, but if I did that would I first update to current FreeNAS? or update after the Clone? Might there by any problems cloning from an 8GB USB stick to a 128GB SATA drive? The manual isn't clear.
- What's the best way to move all my data to a new pool? I've searched the Forums but haven't found a good definitive answer. I have enough SATA ports to attach all of the drives I'll need simultaneously.
