Executive summary:
I've tripled the RAM in my FreeNAS box and suddenly I'm getting swap space issues. I don't understand this but I would like to solve it.
Full story:
After my boot USB failed I decided to switch to a small SSD as boot device, and while I had my hands in the box I added 16GB to the existing 8GB of memory. Once I had reclosed the chest cavity I installed the 9.3 software and uploaded my config file.
All looked great, so I scrubbed the storage. Part way through the web UI stopped responding, so I switched to the console, and lo, the machine was complaining about swap space. After the scrub completed the web UI stayed down so I did an orderly restart, voila, it's alive. Good.
But I don't want to have this happening. The machine is presently a 24GB system with an AMD Bulldozer CPU, a 30GB SSD for boot and 6 4TB drives in a RaidZ2 configuration in a single pool. The default 12GB (2 per drive) of swap is allocated.
So the questions:
- Any idea why this started happening AFTER I added RAM?
- Does the move to 9.3 have any bearing?
- Should I have more swap?
Proposed solution:
Would it work if I added a drive, made it a single drive vdev in a new pool, and set the swap per drive for that pool to be some huge value? For instance I have some slightly pre-loved SSDs (another 30, and a 120) that I could use for this, or I also have some reasonably fast HDDs of around 1TB capacity I could use this way.
- Can I in effect essentially dedicate a drive/vdev/pool to being swap by doing this?
- Would it help?
- Would it be recommended for or against?
- If I have a dedicated swap pool, would it be safe to rebuild the main storage pool with no swap?
Full story:
So the questions:
Proposed solution:
- Would it help?
