With the new swap setup for 11.1, I have started receiving a lot of swap errors. With the swap partitions now mirrored, I am now using only half of the swap i used before. (6 drive raiz2 pool with 2GB swap partitions) Would it be feasible to edit the System>Advanced swap setting to increase the value (say from 2 to 4 or higher), and systematically wipe and replace each disk?
Would the wipe feature repartition the disk and resilver it?
Cheers!
Cheers!
