ezekiel.incorrigible
- Aug 10, 2018
tl;dr: How can I wipe a disk?
I'm running FreeNAS 11.1-u5, I imported the config from another FreeNAS install that was attached to another volume so as to get all of the previously configured users and groups and I'm trying to setup a new mirrored ZVOL with two 1TB disks that I had previously deleted the existing partitions of using parted in linux but the process fails during the initial wipe phase.
It appears that FreeNAS has created itself a swap partition on one of the blank disks and, no matter what I do to the FreeNAS config or to the disk, I can't get it to relinquish the disk.
I managed to successfully wipe one of the disks from the webGUI after enabling 'shoot myself in the foot mode' in the shell with:
If I try and wipe in the webGUI, I get:
If I try and inspect from the shell I notice that there is a (live) swap partition on ada3 but disabling it does not make any difference to the above errors when attempting to wipe.
I tried setting Swap size to 0 in the GUI System->Advanced settings and saving and rebooting but it doesn't appear to actually disable swapping - the swap was remounted on reboot and present in /etc/fstab. I tried manually writing over the GPT and swap partition with 2.5GB of zeroes by putting the disk into a linux system (which was unable to see any partitions at all) and running
Attempting to disable swapping in the shell and then deleting the partitions using GPART is met with 'device busy' although I can't see with what.
sysctl kern.geom.debugflags=16
but the other disk still fails with an error and if I attempt to delete its partitions with gpart, it reports that it is busy.If I try and wipe in the webGUI, I get:
[MiddlewareError: Failed to wipe ada3p1: dd: /dev/ada3p1: Operation not permitted]
root@freenasbackup:~ # mount -v freenas-boot/ROOT/default on / (zfs, local, noatime, nfsv4acls, fsid 17f017f6dea35f55) devfs on /dev (devfs, local, multilabel, fsid 00ff007171000000) tmpfs on /etc (tmpfs, local, fsid 01ff008787000000) tmpfs on /mnt (tmpfs, local, fsid 02ff008787000000) tmpfs on /var (tmpfs, local, fsid 03ff008787000000) freenas-boot/grub on /boot/grub (zfs, local, noatime, nfsv4acls, fsid ef7017c9dee2386c) fdescfs on /dev/fd (fdescfs, fsid 05ff005959000000) tmpfs on /var/db/collectd/rrd (tmpfs, local, fsid 06ff008787000000) root@freenasbackup:~ # gpart show ada3 => 40 1953525088 ada3 GPT (932G) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 1949330696 - free - (930G)
dd if=/dev/zero of=/dev/sdb bs=1M count=2500
- this made no difference, booting back up with FreeNAS showed the same 2GB freebsd-swap partition had been created and mounted again.Attempting to disable swapping in the shell and then deleting the partitions using GPART is met with 'device busy' although I can't see with what.
root@freenasbackup:~ # swapoff -a swapoff: removing /dev/ada3p1.eli as swap device root@freenasbackup:~ # swapctl -l Device: 1024-blocks Used: root@freenasbackup:~ # gpart create -s GPT ada3 gpart: geom 'ada3': File exists root@freenasbackup:~ # gpart delete -i 1 ada3 gpart: Device busy root@freenasbackup:~ # gpart destroy -F ada3 gpart: Device busy root@freenasbackup:~ # fstat /dev/ada3 USER CMD PID FD MOUNT INUM MODE SZ|DV R/W NAME root@freenasbackup:~ # lsof /dev/ada3 lsof: WARNING: compiled for FreeBSD release 11.0-RELEASE; this is 11.1-STABLE. root@freenasbackup:~ # dd if=/dev/zero of=/dev/ada3 bs=1M count=100 100+0 records in 100+0 records out 104857600 bytes transferred in 0.559097 secs (187548300 bytes/sec) root@freenasbackup:~ # ls /dev | grep ada3 ada3 ada3p1 ada3p1.eli root@freenasbackup:~ # gpart delete -i 1 ada3p1 gpart: arg0 'ada3p1': Invalid argument root@freenasbackup:~ # gpart delete -i 2 ada3 gpart: index '2': No such file or directory root@freenasbackup:~ # gpart delete -i 3 ada3 gpart: index '3': No such file or directory
