Have a four-drive RAIDZ1 pool and one drive (ada1) is degraded. I watched this tutorial, which seems simple enough. However, he has the luxury of already having quasi-hot spares in place. So he can initiate the replacement in-place.
I would have to connect a fifth drive either using a USB-to-SATA adapter, or using a SATA expansion card I have inside the TrueNAS.
The new drive would ostensibly show up as a different device in /dev/. I could then replace it in the same fashion he does.
But what happens when I shut down, pull out the bad drive, and pop the replacement into the now-empty bay? Once it boots up, I imagine the new drive would show up as /dev/ada1. Will it 'just work' from there? Or will there be another step to take because of the dev name change?
TIA
TIA
