sremick
- Sep 24, 2014
So originally when I upgraded to 11.2, all 6 of my drives were reporting temps.
But now, /dev/ada2 is showing "N/A" for temperature in the Dashboard. All the other drives show a temp correctly.
smartctl -a /dev/ada2 correctly reports a temp, so it's not that the drive isn't providing it.
What might be going on?
(I know of the read errors in the logs, but those are from weeks ago and the drive hasn't reported any new ones. I'm keeping an eye on it.)
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD30EFRX-68EUZN0 Serial Number: xxxxxxxxxxxxxxxx LU WWN Device Id: 5 0014ee 604fc6e6e Firmware Version: 82.00A82 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Jan 3 20:27:36 2019 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (40680) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 408) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 79 3 Spin_Up_Time 0x0027 177 176 021 Pre-fail Always - 6116 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 76 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 051 051 000 Old_age Always - 36356 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 76 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 46 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 396 194 Temperature_Celsius 0x0022 111 102 000 Old_age Always - 39 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 14 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 90% 36147 1433664792 # 2 Extended offline Completed: read failure 90% 36053 1433664792 # 3 Short offline Completed: read failure 10% 35980 1565560512 # 4 Extended offline Completed: read failure 90% 35720 1433664793 # 5 Short offline Completed: read failure 90% 35647 1433664793 # 6 Extended offline Completed: read failure 10% 35508 1565560512 # 7 Short offline Completed: read failure 90% 35500 1433664792 # 8 Short offline Completed without error 00% 14332 - # 9 Extended offline Completed without error 00% 14244 - #10 Short offline Completed without error 00% 14164 - #11 Short offline Completed without error 00% 13996 - #12 Extended offline Completed without error 00% 13909 - #13 Short offline Completed without error 00% 13828 - #14 Short offline Completed without error 00% 13588 - #15 Extended offline Completed without error 00% 13501 - #16 Short offline Completed without error 00% 13420 - #17 Short offline Completed without error 00% 13252 - #18 Extended offline Completed without error 00% 13178 - #19 Short offline Completed without error 00% 13097 - #20 Short offline Completed without error 00% 12882 - #21 Extended offline Completed without error 00% 12794 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
