Hi All,
I took a look at the thread about diagnosing drive failures and just wanted to know how severe my particular failure is. I ran a short test and came up with these results:
I'm currently running a long test which will finish in a few hours I'm hoping but just wanted to get the ball rolling with troubleshooting and if I should worry yet or not.
Thanks!
root@freenas:~ # smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68AX9N0
Serial Number: WD-WMC1T1118726
LU WWN Device Id: 5 0014ee 602e3af15
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jun 21 19:19:07 2020 PDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 118) The previous self-test completed having
the read element of the test failed.
data collection: (40080) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 402) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 184 165 021 Pre-fail Always - 5766
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3733
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 017 017 000 Old_age Always - 60599
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 139
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 84
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3648
194 Temperature_Celsius 0x0022 107 102 000 Old_age Always - 43
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 60% 60585 1565557560
# 2 Short offline Completed: read failure 60% 60536 1565557560
# 3 Short offline Completed: read failure 60% 60488 1565557560
# 4 Extended offline Completed: read failure 10% 60443 1565557560
# 5 Short offline Completed: read failure 60% 60392 1565562080
# 6 Short offline Completed: read failure 60% 60344 1565562080
# 7 Short offline Completed: read failure 60% 60296 1565562080
# 8 Short offline Completed: read failure 60% 60248 1565562096
# 9 Short offline Completed: read failure 60% 60200 1565562096
#10 Short offline Completed: read failure 60% 60152 1565562080
#11 Extended offline Completed: read failure 10% 60107 1565562080
#12 Short offline Completed: read failure 60% 60082 1565562080
#13 Short offline Completed without error 00% 60032 -
#14 Short offline Completed without error 00% 59984 -
#15 Short offline Completed without error 00% 59936 -
#16 Short offline Completed without error 00% 59888 -
#17 Short offline Completed without error 00% 59840 -
#18 Short offline Completed without error 00% 59792 -
#19 Short offline Completed without error 00% 59745 -
#20 Extended offline Completed without error 00% 59700 -
#21 Short offline Completed without error 00% 59649 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Thanks!
