How do I interpreter this SMART result?
plutonium
Hi, I need some help to interpreters this result. Is my harddrive broken?
Thanks for the help :)
[root@freenas] ~# smartctl -a /dev/da3
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:  Western Digital Red
Device Model:  WDC WD30EFRX-68EUZN0
Serial Number:  WD-WMC4N1551572
LU WWN Device Id: 5 0014ee 003bb2daa
Firmware Version: 80.00A80
User Capacity:  3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:  512 bytes logical, 4096 bytes physical
Rotation Rate:  5400 rpm
Device is:  In smartctl database [for details use: -P show]
ATA Version is:  ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:  Sat Mar 11 14:44:43 2017 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
  was never started.
Self-test execution status:  ( 248) Self-test routine in progress...
  80% of test remaining.
data collection:  (40980) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
Short self-test routine
recommended polling time:  (  2) minutes.
Extended self-test routine
recommended polling time:  ( 411) minutes.
Conveyance self-test routine
recommended polling time:  (  5) minutes.
SCT capabilities:  (0x703d) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x002f  200  200  051  Pre-fail  Always  -  0
  3 Spin_Up_Time  0x0027  175  172  021  Pre-fail  Always  -  6225
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  52
  5 Reallocated_Sector_Ct  0x0033  200  200  140  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x002e  200  200  000  Old_age  Always  -  0
  9 Power_On_Hours  0x0032  065  065  000  Old_age  Always  -  25968
 10 Spin_Retry_Count  0x0032  100  253  000  Old_age  Always  -  0
 11 Calibration_Retry_Count 0x0032  100  253  000  Old_age  Always  -  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  52
192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always  -  51
193 Load_Cycle_Count  0x0032  200  200  000  Old_age  Always  -  15
194 Temperature_Celsius  0x0022  102  092  000  Old_age  Always  -  48
196 Reallocated_Event_Count 0x0032  200  200  000  Old_age  Always  -  0
197 Current_Pending_Sector  0x0032  200  200  000  Old_age  Always  -  0
198 Offline_Uncorrectable  0x0030  100  253  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x0032  200  200  000  Old_age  Always  -  0
200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline  -  1
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline  Completed: read failure  60%  25908  1565563136
# 2  Extended offline  Completed: read failure  10%  25904  1565563136
# 3  Extended offline  Completed: read failure  10%  25856  1565563136
# 4  Short offline  Completed: read failure  60%  25836  1565563136
# 5  Short offline  Completed: read failure  60%  25764  1565563136
# 6  Extended offline  Completed: read failure  10%  25760  1565563136
# 7  Extended offline  Completed: read failure  10%  25712  1565563136
# 8  Short offline  Completed: read failure  10%  25693  1565563136
# 9  Short offline  Completed: read failure  10%  25622  1565563136
#10  Extended offline  Completed: read failure  10%  25617  1565563136
#11  Short offline  Completed: read failure  10%  25501  1565563136
#12  Extended offline  Completed: read failure  10%  25500  1565563136
#13  Extended offline  Completed: read failure  10%  25449  1565563136
#14  Short offline  Completed: read failure  10%  25431  1565563136
#15  Short offline  Completed: read failure  60%  25357  1565563136
#16  Extended offline  Completed: read failure  10%  25352  1565563136
#17  Short offline  Completed: read failure  10%  25242  1565563136
#18  Extended offline  Completed: read failure  10%  25232  1565563136
#19  Extended offline  Completed: read failure  10%  25185  1565563136
#20  Short offline  Completed: read failure  40%  25165  1565563136
#21  Short offline  Completed: read failure  60%  25094  1565563136
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Mr_N
lots of tests that all failed, i'd say thats a good guess :)
Jailer
Not strong, but bad
Yup, it's failing. If it's still under warranty RMA it.
plutonium
Thanks for your answer!
Looks like my warranty time is out :/
Serial Number WMC4N1551572
Out of Limited Warranty
Model Number WD30EFRX
Description WD Red
Expiration Date 02/08/2017
Jailer
Not strong, but bad
Bummer, missed it by a month. Better start shopping for a new drive.
Mr_N
well it did start failing about 800 hrs prior so still within warranty then I'm guessing :|
Glorious1
Drive is running at 48 C - too hot.
Robert Trevellyan
Pony Wrangler
Is that based on date of manufacture or date of purchase? You have to register the serial # with WD to get the warranty to run from date of purchase, otherwise it defaults to date of manufacture.
