Failed disk - is it still useful?
Benc
I replaced failed drive and now I am trying to figure out if it is still good enough for some less important use. I'm running smart test and short test sometimes finishes but long one never got till the end. I usually get error 121, sometimes 117.
This is last info:
Model Family:	 Western Digital Red
Device Model:	 WDC WD20EFRX-68AX9N0
Serial Number:	WD-WMC300579709
LU WWN Device Id: 5 0014ee 058cfc5e0
Firmware Version: 80.00A80
User Capacity:	2 000 398 934 016 bytes [2,00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:	Wed Jan 24 15:08:17 2018 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x04) Offline data collection activity
										was suspended by an interrupting command from host.
Self-test execution status:	  ( 121) The previous self-test completed having
										the read element of the test failed.
data collection:				(27360) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 276) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x70bd) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   15
  3 Spin_Up_Time			0x0027   177   174   021	Pre-fail  Always	   -	   4125
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   58
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   054   053   000	Old_age   Always	   -	   33596
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   58
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   40
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   17
194 Temperature_Celsius	 0x0022   117   102   000	Old_age   Always	   -	   30
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   5
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   9
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed: read failure	   90%	 33595		 2000382808
# 2  Short offline	   Completed: read failure	   90%	 33595		 2000382320
# 3  Short offline	   Completed: read failure	   90%	 33595		 2000382216
# 4  Short offline	   Completed: read failure	   90%	 33594		 2000382096
# 5  Short offline	   Completed: read failure	   90%	 33594		 2000382096
# 6  Short offline	   Completed: read failure	   90%	 33594		 2000382096
# 7  Extended offline	Completed: read failure	   90%	 33594		 2000382032
# 8  Extended offline	Completed: read failure	   90%	 33593		 2000382016
# 9  Extended offline	Completed: read failure	   90%	 33593		 2000381504
#10  Extended offline	Completed: read failure	   90%	 33593		 2000381472
#11  Extended offline	Completed: read failure	   90%	 33593		 2000381464
#12  Extended offline	Completed: read failure	   90%	 33593		 2000381320
#13  Extended offline	Completed: read failure	   90%	 33593		 2000380384
#14  Extended offline	Completed: read failure	   90%	 33593		 2000379089
#15  Extended offline	Completed: read failure	   50%	 33593		 1885735736
#16  Extended offline	Completed: read failure	   90%	 33590		 2000376616
#17  Extended offline	Completed: read failure	   90%	 33590		 2000374288
#18  Extended offline	Completed: read failure	   90%	 33583		 2000374216
#19  Conveyance offline  Completed: read failure	   90%	 33582		 2000371608
#20  Short offline	   Completed without error	   00%	 33582		 -
#21  Short offline	   Completed: read failure	   90%	 33582		 1997625041
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Is it possible to make any conclusion from this numbers, can I try anything else or should I throw it away?
Chris Moore
Because of the multi zone error rate and the current pending sectors, I would say that you shouldn't chance it. If the drive is under warranty, send it back for replacement. If it is not under warranty, you should dispose of it.
That is what I would do. I have been burned too many times by a hard drive failure. I just don't take the chance any more.
Benc
I was hoping it could be used as a occasional transfer drive but I guess bad sectors should be 'stable' (I am not sure of proper expression for this). Anyway, if I can't even finish smart test, that is not an option. Drive is also long out of warranty.
tvsjr
It's dead, Jim.
