Benc
 - Nov 5, 2015
I replaced failed drive and now I am trying to figure out if it is still good enough for some less important use. I'm running smart test and short test sometimes finishes but long one never got till the end. I usually get error 121, sometimes 117.
This is last info:
Is it possible to make any conclusion from this numbers, can I try anything else or should I throw it away?
			This is last info:
Model Family: Western Digital Red Device Model: WDC WD20EFRX-68AX9N0 Serial Number: WD-WMC300579709 LU WWN Device Id: 5 0014ee 058cfc5e0 Firmware Version: 80.00A80 User Capacity: 2 000 398 934 016 bytes [2,00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Wed Jan 24 15:08:17 2018 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x04) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Disabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (27360) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 276) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 15 3 Spin_Up_Time 0x0027 177 174 021 Pre-fail Always - 4125 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 58 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 054 053 000 Old_age Always - 33596 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 58 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 40 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 17 194 Temperature_Celsius 0x0022 117 102 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 5 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 9 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: read failure 90% 33595 2000382808 # 2 Short offline Completed: read failure 90% 33595 2000382320 # 3 Short offline Completed: read failure 90% 33595 2000382216 # 4 Short offline Completed: read failure 90% 33594 2000382096 # 5 Short offline Completed: read failure 90% 33594 2000382096 # 6 Short offline Completed: read failure 90% 33594 2000382096 # 7 Extended offline Completed: read failure 90% 33594 2000382032 # 8 Extended offline Completed: read failure 90% 33593 2000382016 # 9 Extended offline Completed: read failure 90% 33593 2000381504 #10 Extended offline Completed: read failure 90% 33593 2000381472 #11 Extended offline Completed: read failure 90% 33593 2000381464 #12 Extended offline Completed: read failure 90% 33593 2000381320 #13 Extended offline Completed: read failure 90% 33593 2000380384 #14 Extended offline Completed: read failure 90% 33593 2000379089 #15 Extended offline Completed: read failure 50% 33593 1885735736 #16 Extended offline Completed: read failure 90% 33590 2000376616 #17 Extended offline Completed: read failure 90% 33590 2000374288 #18 Extended offline Completed: read failure 90% 33583 2000374216 #19 Conveyance offline Completed: read failure 90% 33582 2000371608 #20 Short offline Completed without error 00% 33582 - #21 Short offline Completed: read failure 90% 33582 1997625041 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
