Hi everyone
I've successfully installed an Eaton UPS 9130 with 2000 VA on FreeNAS-9.10.2-U1
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9130.aspx
I purchased it based on the published compatibility here:
http://networkupstools.org/ddl/Eaton/Powerware_9130.html
Configuration was simple.
Open a root terminal, either via SSH access, or accessing the web based Shell on the FreeNAS web interface and type the following:
Press enter/return.
The resulting output will look something like the following. This assumes that you used the USB cable to connect the UPS to your server.
Take note of the USB device name ugen0.4 from the output above and enter it into the Port: setting below.
Important: Your USB device name may be different to mine.
Access the UPS configuration section via the web interface:
Services -> UPS -> UPS Settings
Complete the following settings:
UPS Mode: master
Identifier: Eaton9130 (you can type what you wish, here)
Driver: Eaton ups 5 Powerware 9130 (bcmxcp or usbhid-ups)
Port: /dev/ugen0.4 (note the prefix of /dev followed by the USB device name, as above)
Description: Eaton9130 (you can type what you wish, here)
Shutdown mode: UPS reaches low battery (this was my preference)
The remaining settings can be left, as per the defaults.
Scroll down and click OK
I haven't yet tested the shutdown behaviour, so will report back when done.
dmesg | grep EATON
Press enter/return.
ugen0.4: <EATON Powerware> at usbus0
UPS Mode: master
