Hi All,
New to the forums and FreeNAS in general, let me know if I've made some faux par here or posted this in the wrong place!
I'm getting the daily emails from my FreeNAS which I'm perfectly happy to receive, however, for the last two days the emails have consisted only of:
Which I get the impression from reading other peoples forum posts on the topic is not what I should be getting?
I have checked using Shell and found that the /var/log directory does exist but doesn't contain either of these files...
Also (if it makes any difference) in my NAS GUI under System > System Dataset, I had neither "Syslog" nor "Reporting Dataset" selected. I have just enabled "Syslog" in case that makes any difference.
Specs as follows:
Build: FreeNAS-11.1-U2
Motherboard: Gigabyte GA-B250M-D3H
CPU: Intel i3-7100
RAM: 16GB DDR4 @ 2400Mhz
HDDS: 2x3TB WD Reds in Mirror + 2x4TB WD Reds in Mirror. 16GB USB3 Flashdrive for FreeNAS OS.
Built in ethernet connection.
Many thanks in advance!
William
EDIT: Added Specs
No /var/log/mount.today No /var/log/dmesg.today -- End of security output --
Specs as follows:
CPU: Intel i3-7100
William
EDIT: Added Specs
