adrianwi
- Oct 15, 2013
I've converted most of my jails to iocage, and like I did with the warden ones I snapshot the top level dataset (/mnt/tank/iocage) with recursive ticked so they transfer across to my 2nd freenas box.
Everything had been working fine until yesterday when I destroyed an iocage jail (emby) and then recreated one with exactly the same name. The jail is working fine, although some of the snapshots from a different jail (embyms) seem to have got messed up, and I'm now getting these messages e-mailed every few hours:
I've looked at the snapshots and they look like any other periodic snapshot, with the exception of these in the ../iocage/releases/11.1-RELEASE/root folder:
These are named differently to the auto-date snapshots I typically see, and I can't delete them as get the following message:
This appears to be the iocage jail folder, which I probably don't want to remove as I want this copied to my backup box.
Any idea what's going on here, and how I fix it?
Thanks
Just noticed I'm getting a flood of these at the other end, the root folder doesn't exist and I can't created it as the file system is read-only:
Replication APEpool1/iocage -> 192.168.168.65:APEpool2 failed: Failed: APEpool1/iocage/releases/11.1-RELEASE/root (embyms->emby) Hello, The replication failed for the local ZFS APEpool1/iocage/releases/11.1-RELEASE/root while attempting to apply incremental send of snapshot embyms -> emby to 192.168.168.65
Thanks
Jul 21 13:27:07 freenas2 collectd[3221]: statvfs(/mnt/APEpool2/iocage/jails/emby/root) failed: No such file or directory Jul 21 13:27:17 freenas2 collectd[3221]: statvfs(/mnt/APEpool2/iocage/jails/emby/root) failed: No such file or directory Jul 21 13:27:27 freenas2 collectd[3221]: statvfs(/mnt/APEpool2/iocage/jails/emby/root) failed: No such file or directory Jul 21 13:27:37 freenas2 collectd[3221]: statvfs(/mnt/APEpool2/iocage/jails/emby/root) failed: No such file or directory Jul 21 13:27:47 freenas2 collectd[3221]: statvfs(/mnt/APEpool2/iocage/jails/emby/root) failed: No such file or directory Jul 21 13:27:57 freenas2 collectd[3221]: statvfs(/mnt/APEpool2/iocage/jails/emby/root) failed: No such file or directory
