Cant see the files inside my mount point inside of jail
Cytomax
FreeNAS-11.2-BETA1
wget https://raw.githubusercontent.com/MediaBrowser/iocage-amd64/master/emby-server.json
iocage fetch -P --name emby-server.json ip4_addr="em0|192.168.0.4/24”
mkdir /mnt/iocage/jails/emby-server/root/media/Movies
iocage fstab -a emby-server "/mnt/volume/windowsset/Movies/Movies_Downloads /mnt/iocage/jails/emby-server/root/media/Movies nullfs rw 0 0"
iocage fstab -l emby-server
root@freenas:~ # iocage fstab -l emby-server
| INDEX |																  FSTAB ENTRY																   |
| 0	 | /mnt/iocage/releases/11.1-RELEASE/root/bin /mnt/iocage/jails/emby-server/root/bin nullfs ro 0 0												|
| 1	 | /mnt/iocage/releases/11.1-RELEASE/root/boot /mnt/iocage/jails/emby-server/root/boot nullfs ro 0 0											  |
| 2	 | /mnt/iocage/releases/11.1-RELEASE/root/lib /mnt/iocage/jails/emby-server/root/lib nullfs ro 0 0												|
| 3	 | /mnt/iocage/releases/11.1-RELEASE/root/libexec /mnt/iocage/jails/emby-server/root/libexec nullfs ro 0 0										|
| 4	 | /mnt/iocage/releases/11.1-RELEASE/root/rescue /mnt/iocage/jails/emby-server/root/rescue nullfs ro 0 0										  |
| 5	 | /mnt/iocage/releases/11.1-RELEASE/root/sbin /mnt/iocage/jails/emby-server/root/sbin nullfs ro 0 0											  |
| 6	 | /mnt/iocage/releases/11.1-RELEASE/root/usr/bin /mnt/iocage/jails/emby-server/root/usr/bin nullfs ro 0 0										|
| 7	 | /mnt/iocage/releases/11.1-RELEASE/root/usr/include /mnt/iocage/jails/emby-server/root/usr/include nullfs ro 0 0								|
| 8	 | /mnt/iocage/releases/11.1-RELEASE/root/usr/lib /mnt/iocage/jails/emby-server/root/usr/lib nullfs ro 0 0										|
| 9	 | /mnt/iocage/releases/11.1-RELEASE/root/usr/libexec /mnt/iocage/jails/emby-server/root/usr/libexec nullfs ro 0 0								|
| 10	| /mnt/iocage/releases/11.1-RELEASE/root/usr/sbin /mnt/iocage/jails/emby-server/root/usr/sbin nullfs ro 0 0									  |
| 11	| /mnt/iocage/releases/11.1-RELEASE/root/usr/share /mnt/iocage/jails/emby-server/root/usr/share nullfs ro 0 0									|
| 12	| /mnt/iocage/releases/11.1-RELEASE/root/usr/libdata /mnt/iocage/jails/emby-server/root/usr/libdata nullfs ro 0 0								|
| 13	| /mnt/iocage/releases/11.1-RELEASE/root/usr/lib32 /mnt/iocage/jails/emby-server/root/usr/lib32 nullfs ro 0 0									|
| 14	| /mnt/volume/windowsset/Movies/Movies_Downloads /mnt/iocage/jails/emby-server/root/mnt/iocage/jails/emby-server/root/media/Movies nullfs rw 0 0 |
Restart FreeNAS
iocage console emby-server
cd /media
ls -al
drwxr-xr-x 2 root wheel 2 Jul 29 11:45 Movies
cd /media/Movies
ls
shows nothing
If i exit the jail console and am back inside of FreeNAS
cd /mnt/iocage/jails/emby-server/root/mnt/iocage/jails/emby-server/root/media/Movies
ls
shows everything
What am i doing wrong?
cd /media/Movies
ls
shows nothing
It wouldn't--you told the jail to mount it at /mnt/iocage/jails/emby-server/root/media/Movies. If that directory exists in your jail, and you go to it, you should see your files.
Cytomax
ty for the response
I am sure you are aware and i may be mistaken but
when i type
I thought i would be inside the jail at /mnt/iocage/jails/emby-server/root
so all i have to do is go to /media/Movies which should show me all the stuff at /mnt/volume/windowsset/Movies/Movies_Downloads
i may be wrong i am pretty new to iocage
thanks in advance
When you do:
The first path argument is the "source", i.e., what path on your FreeNAS box do you want to make available to the jail. The second is the destination--where should that path appear within the jail. If you wanted it to appear as /media/Movies inside the jail, you should have done:
iocage fstab -a emby-server "/mnt/volume/windowsset/Movies/Movies_Downloads  /media/Movies nullfs  rw  0  0"
Cytomax
ty very much
awwwww pooop... i just nuked my system and reinstalled 11.1 ...... now i wanna try again....
1 last thing.. i dont see any option for iocage to make a directory if the directory doesnt exit when creating the mount points... any thing speical or i just manually mkdir since its still in beta and kinds are being ironed out?
