Flood of iocage related messages
I am getting a flood of messages related to missing /mnt/backup/iocage, posted every 10 seconds:
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/download) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/download/11.1-RELEASE) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/images) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/handbrake2) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/handbrake2/root) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/nc) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/nc/root) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/nc2) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/nc2/root) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/plex2) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/jails/plex2/root) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/log) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/releases/11.1-RELEASE) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/releases/11.1-RELEASE/root) failed: No such file or directory
Feb 17 21:11:00 big_bertha collectd[4516]: statvfs(/mnt/backup/iocage/templates) failed: No such file or directory
I'm running FreeNAS-11.1-U1. When I first started using iocage, the first use of iocage caused it to activate on /mnt/backup, which is used as a backup target, and it not itself backed up. I wanted iocage to use /mnt/main, as that is backed up to multiple places. Fortunately I detected the wrong location for iocage before wasting too much time, so I did an iocage clean to clean it out, then iocate activate /mnt/main. But, it looks like the original wrong location of iocage is perhaps a cause of this flood of messages.
I'd appreciate any advice on why I'm seeing these messages, what the implications are, and how to fix the problem.
Thanks,
Kevin
D
dlavigne
Guest
Does this issue persist with U2? If so, it may be worth reporting at bugs.freenas.org. If you do, post the issue number here?
I am waiting a bit before updating to U2, to see if any major issues are found by the early adopters. I'll report back once I've updated to U2.
Sadly, the flood of messages every 10s persists after updating to FN 11.1-U2.
I created Issue 28736 for this.
