ovalcoconut
- Feb 11, 2018
I have one volume I've named 'D'
I have two disks in this volume, one 1TB HDD, and one 2TB HDD.
My data takes up 1.6TB. I started with the 1TB HDD as that was what I had at the time, then I bought the 2TB HDD, and added to the system a month later for more storage. Now I'm realizing the error in my ways, and I'd like to move all of my data onto the 2TB HDD, and then make the 1TB HDD a separate Volume, so I can add/replace either disk at will. my data only takes up 1.6TB so I'm assuming it should be perfectly fine.
My end goal is to get my 1.6TB onto my 2TB HDD, in a volume named 'D'. Along with my 1TB HDD empty, and in a separate volume named 'E'
I have serveral pluggins with linked storage and users configured, I'd hate to have to redo all of that. I also want my data to be safe if one of my drives fail.
I have a few questions related to the matter:
In my current setup, it seems like the two disks are being treated as one. Are they? and if I remove one will I be able to access part of my data? or will is the data spread across the disks like a raid?
Will I need additional storage to do what I want?
What is the best practice for using multiple disks? Is there a 'correct' way?
How do you organize terabytes of media?
Thanks for your time.
