wittend
- Oct 10, 2022
A new user to TrueNAS/FreeNAS, I have been trying to install TrueNAS Core 13.0 U2 (and alternately TrueNAS Scale 13.0 22.02.4) on an unlovely but heretofore reliable ASRock H77M-ITX motherboard.
This board hardware setup is as follows:
(Readinfg from UEFI Setup Screen)
UEFI H77M-ITZ P1.10
CPU: Intel Core i7-2700k CPU @3.50 GHz
CPU speed: 3500 Mhz
Microcode Update: 206A7/25
Cache Size: 8192 KB
DDR_A1: 8196 MB (DDR-1333)
DDR_B1: 8196 MB (DDR-1333)
Total DDR3: 16384 MB with265 MB Shared memory and 2MB GTT Memory
Intended Boot volume: Crucial 126 GB Crucial SSD (Sata IF)
Intended Storage volumes: 3 (for testing) or 4 (in the end) WD4003FFBX 'NASware' 4 TB Red Pro 7200 rpm drives
Installing from memory stick image.
I have tried to be systematic, and spent 2.5 days patiently (sort of) changing BIOS parameters one at a time and rebooting with what seems to me to be every possible combination allowed.
I have tried USB PMAP and USB UEFI-PMAP. USB 3 and especially USB2
I've tried both HardDisk Driver and Solid State Drive options where I can. Enabled and disabled external SATA. options.
I have diddled and re-diddled the boot order options.
I have changed everything that can be changed, I think.
In all cases the system expands the installation image but then cannot find some essential component
I have tried to 'Instant Flash' (Image not found) or 'Internet Flash' (total system lock up every time) with the latest available approved and beta BIOS images.
I recognize that this is an old, unlovely motherboard designed and tested for Windows desktop use by a manufacturer who has little regard for other OS's.
But it installs Mint (Ubuntu) (including ZFS option) without fail.
Is there anything else that I can do?
-dave
UEFI H77M-ITZ P1.10
CPU speed: 3500 Mhz
Cache Size: 8192 KB
-dave
