I can't understand why there is permanently messed things up with SMBs after upgrades. It cost me half a day already with no clue what the matter is.
Situation :
I normally have SMB mounts from TrueNAS to Windows, these SMB mounts are mounted as network shares and are also shared with several VMs (VMWare Workstation Pro). This was working like a charm until I upgraded today in the morning.
The SMB mounts in Windows are still there, but something is different, as I cannot access the directories in my VMs anymore. If you mount them with allow_other (normally done via fstab) they have simply no permissions at all anymore in the guests, it looks like this then
d---------. 1 root root 0 Oct 14 10:43 Cinema_I
You can also mount them with uid, gid, umask, that all does not help the slightest. Even if you do
What I did :
Completely remap the ACLs in TrueNAS
Completely disconnected shares in Windows, even deleted the credentials from credential manager, completely reconnected shares in Windows
Completely removed the shares from VMs and reapplied them
Set up several new VMs with several different versions of fuse and open-vm-tools (Fedora, Alma), and set up the shared folders from scratch
It all leads to exactly the same issue, the folders are not accessible anymore
This drives me literally crazy, but it all comes down to the upgrade because all else was checked as you can see above, there is nothing to get that working. There were no updates to VMWare done, it is the same version since more than half a year. New guest installs were completely from scratch
So it would be nice if someone could tell me what exactly you did to SMB and how to fix that issue for U6 because I am not able to do my work anymore
Many thanks
Situation :
[root@localhost mnt]# /usr/bin/vmhgfs-fuse .host:Cinema_I /mnt/Cinema_I -o subtype=vmhgfs-fuse,allow_other,uid=1000,gid=1000,umask=007 [root@localhost mnt]# ll /mnt total 0 drwxrwx---. 1 tg tg 0 Oct 14 10:43 Cinema_I [root@localhost mnt]# cd /mnt/Cinema_I/ -bash: cd: /mnt/Cinema_I/: Permission denied [root@localhost mnt]#
What I did :
Many thanks
