NadoNate
- Aug 7, 2017
I'm having an issue getting the SMART service to start on a new build.
SPECS:
Dell PowerEdge T630 - BIOS 2.7.1
CPU - Xeon E5-2680 (2)
Memory - 64GB ECC
SAS - PERC H730 HBA Mode - Firmware 4.270.00-8178
Pool - 1 Z3 9 drives
FreeNas Version - 11.1-U4
Issue:
When I try to enable the SMART service from the UI it hangs, than fails to start, accompanied by this message:
My drives are reporting smart capabilities, they are being mounted properly:
Doing some research I found the H730 is more reliable using the mrsas drivers, so I've added a tunable per the recommendation here:
http://doc.freenas.org/9.10/intro.html
(Variable)
This doesn't seem to help, although I am not sure freenas is using the mrsas drivers. Is there a way to verify this?
I've read a suggestion to enable mrsas during a freebsd installation here: https://forums.freebsd.org/threads/change-storage-driver-during-install.54222/ But this may only apply to UEFI....?
SPECS:
Memory - 64GB ECC
Issue:
smartd[2908]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries
root@ASNAS:~ # smartctl -a /dev/da1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 3.5 Device Model: ST4000DM004-2CV104 Serial Number: ZFN055SC LU WWN Device Id: 5 000c50 0a3e7cb7e Firmware Version: 0001 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5425 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Apr 9 11:29:15 2018 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled
root@ASNAS:~ # camcontrol devlist <ATA ST4000DM004-2CV1 0001> at scbus1 target 0 lun 0 (pass0,da0) <ATA ST4000DM004-2CV1 0001> at scbus1 target 1 lun 0 (pass1,da1) <ATA ST4000DM004-2CV1 0001> at scbus1 target 2 lun 0 (pass2,da2) <ATA ST4000DM004-2CV1 0001> at scbus1 target 3 lun 0 (pass3,da3) <ATA ST4000DM004-2CV1 0001> at scbus1 target 4 lun 0 (pass4,da4) <ATA ST4000DM004-2CV1 0001> at scbus1 target 5 lun 0 (pass5,da5) <ATA ST4000DM004-2CV1 0001> at scbus1 target 6 lun 0 (pass6,da6) <ATA ST4000DM004-2CV1 0001> at scbus1 target 7 lun 0 (pass7,da7) <ATA ST4000DM004-2CV1 0001> at scbus1 target 8 lun 0 (pass8,da8) <ATA ST4000DM004-2CV1 0001> at scbus1 target 9 lun 0 (pass9,da9) <ATA ST4000DM004-2CV1 0001> at scbus1 target 10 lun 0 (pass10,da10) <ATA TOSHIBA MG04ACA4 FK1D> at scbus1 target 11 lun 0 (pass11,da11) <ATA ST4000DM004-2CV1 0001> at scbus1 target 13 lun 0 (pass12,da12) <ATA ST4000DM004-2CV1 0001> at scbus1 target 14 lun 0 (pass13,da13) <ATA ST4000DM004-2CV1 0001> at scbus1 target 15 lun 0 (pass14,da14) <ATA ST4000DM004-2CV1 0001> at scbus1 target 16 lun 0 (pass15,da15) <ATA ST4000DM004-2CV1 0001> at scbus1 target 17 lun 0 (pass16,da16) <DP BP13G+EXP 3.35> at scbus1 target 32 lun 0 (ses0,pass17) <PLDS DVD+-RW DH-16AES DD1M> at scbus11 target 0 lun 0 (cd0,pass18) <ADATA USB Flash Drive 1100> at scbus13 target 0 lun 0 (pass19,da17) <ADATA USB Flash Drive 1100> at scbus14 target 0 lun 0 (pass20,da18)
(Variable)
