I have FreeNAS 8.0.2 on my HP ProLiant Microserver. At last I could configure SMART for the harddrive and the daemon start normally. But for some reason it seem SMART tests are not running. Here is my smartd.conf file:
# smartd.conf generated by FreeNAS
/dev/ada0 -n never -W 0,0,0 -m ***@***.*** -s S/(01|02|03|04|05|06|07|08|09|10|11|12)/(00)/(1|2|3|4|5|6)/(15)
/dev/ada0 -n never -W 0,0,0 -m ***@***.*** -s L/(01|02|03|04|05|06|07|08|09|10|11|12)/(00)/(7)/(15)
And this is what I get when I enter smartd -q showtests
smartd 5.41 2011-06-09 r3365 [FreeBSD 8.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
Opened configuration file /usr/local/etc/smartd.conf
Drive: /dev/ada0, implied '-a' Directive on line 4 of file /usr/local/etc/smartd.conf
Drive: /dev/ada0, implied '-a' Directive on line 5 of file /usr/local/etc/smartd.conf
Configuration file /usr/local/etc/smartd.conf parsed.
Device: /dev/ada0, opened
Device: /dev/ada0, WDC WD1002FAEX-00Z3A0, S/N:WD-WCATR6367970, WWN:5-0014ee-2b04e0ac4, FW:05.01D05, 1.00 TB
Device: /dev/ada0, found in smartd database.
Device: /dev/ada0, is SMART capable. Adding to "monitor" list.
Monitoring 2 ATA and 0 SCSI devices
Next scheduled self tests (at most 5 of each type per device):
Totals [Tue Nov 22 10:35:55 2011 CET - Mon Feb 20 10:35:55 2012 CET]:
Device: /dev/ada0, will do 0 tests of type L
Device: /dev/ada0, will do 0 tests of type S
Device: /dev/ada0, will do 0 tests of type C
Device: /dev/ada0, will do 0 tests of type O
