Mikael Petersson
- Sep 16, 2014
Hello everyone.
I'm trying to find information on how to run a full smart test after a failed smart tests. i'm sorry if this has been asked before, I've searched but have not found an answer. If you know this allready has been written somewhere please point me to that.
I have one read error on one of my drives after multiple smart tests. But it seams that the tests dont finish at all but stops after first fail. The long test stops after only 10% (from what i can see) and finishes alot faster than the rest of the drives. the short test stops after 50%
Does smart test not continue after first problem?
Is a (one) read error so bad that it throws all other tests?
Would this also mean that the drive could be in much worse state than only one failed LBA read? if so why dont it report that?
Is there any way to continue to do all tests to see what exactly is going on?
The drive is a WD red 3tb drive if that helps and i'm running (latest) freenas 11.2u7.
Thank you
/Micke
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.Code:
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 36582 4187936 # 2 Short offline Completed: read failure 50% 36571 4187936 # 3 Short offline Completed: read failure 50% 36547 4187936 # 4 Short offline Completed: read failure 50% 36523 4187936
Thank you
/Micke
