I updated FreeNAS system a few days ago, at this time I also activated the periodical SMART inspections.
My hard drives are
5 x Western Digital WD30EFRX Red 3TB (RAID-Z2)
1 x Seagate Archive HDD v2 8TB
the rest of the hardware is a HP MicroServer N36L (8 GB RAM).
Unfortunately I now get daily critical warning messages. I'm not sure where this comes from.
From the FreeNAS overview page:
smartctl of /dev/ada2
smartctl of Seagate v2 Archive HDD 8 TB
zpool status
My hard drives are
KRITISCH: Device: /dev/ada4, Read SMART Error Log Failed
KRITISCH: Device: /dev/ada4, failed to read SMART Attribute Data
KRITISCH: Device: /dev/ada2, Self-Test Log error count increased from 0 to 1
~# smartctl -a /dev/ada2
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build)
Model Family: Western Digital Red (AF)
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WMC4N1076300
LU WWN Device Id: 5 0014ee 6040455e9
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Aug 1 12:00:30 2015 CEST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (40680) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 408) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 178 176 021 Pre-fail Always - 6100
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 53
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 13681
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 53
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 45
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 740610
194 Temperature_Celsius 0x0022 119 114 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed: read failure 90% 13672 204275648
# 2 Short offline Completed without error 00% 38 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
~# smartctl -a /dev/ada4
Device Model: ST8000AS0002-1NA17Z
Serial Number: Z8406KXS
LU WWN Device Id: 5 000c50 07b7fc021
Firmware Version: AR13
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5980 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Aug 1 12:01:12 2015 CEST
Warning! SMART Attribute Data Structure error: invalid SMART checksum.
Read SMART Thresholds failed: Input/output error
was never started.
data collection: ( 0) seconds.
capabilities: (0x00) Offline data collection not supported.
SMART capabilities: (0x0000) Automatic saving of SMART data is not implemented.
Error logging capability: (0x00) Error logging supported.
SCT capabilities: (0x30a5) SCT Status supported.
SMART Attributes Data Structure revision number: 3162
255 Unknown_Attribute 0x373f 200 016 --- Pre-fail Always - 69269232549888
32 Unknown_Attribute 0x2020 032 032 --- Old_age Offline - 82687521601568
83 Unknown_Attribute 0x0658 123 039 --- Old_age Offline - 56355641622643
32 Unknown_Attribute 0x2020 032 084 --- Old_age Offline - 91466432524371
48 Unknown_Attribute 0x3230 048 049 --- Old_age Offline - 35395753361709
32 Unknown_Attribute 0x2020 032 032 --- Old_age Offline - 35322350018592
32 Unknown_Attribute 0x2020 032 032 --- Old_age Offline - 550026354720
16 Unknown_Attribute 0x3f00 000 016 --- Old_age Offline - 280775165541372
255 Unknown_Attribute 0x000f 000 007 --- Pre-fail Always - 131943408599808
120 Unknown_Attribute 0x7800 000 000 --- Old_age Offline - 0
68 Unknown_Attribute 0xf000 003 031 --- Old_age Offline - 109390152887040
105 Unknown_Attribute 0x4134 188 099 --- Old_age Offline - 238052190486369
32 Unknown_Attribute 0x0220 000 064 --- Old_age Offline - 6940667217921
10 Spin_Retry_Count 0x003c 000 060 --- Old_age Offline - 134217728
132 Unknown_Attribute 0x0001 139 008 --- Pre-fail Offline - 128
255 Unknown_Attribute 0xbd00 239 000 --- Old_age Offline - 0
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
zpool status
~# zpool status
pool: bpool
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
bpool ONLINE 0 0 0
gptid/04bebf57-32cd-11e5-bbc2-6805ca1b4fa6 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
status: One or more devices are configured to use a non-native block size.
Expect reduced performance.
action: Replace affected devices with devices that support the
configured block size, or migrate data to a properly configured
pool.
scan: scrub repaired 0 in 0h1m with 0 errors on Sun Jul 12 03:46:11 2015
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da0p2 ONLINE 0 0 0 block size: 512B configured, 8388608B native
da1p2 ONLINE 0 0 0
pool: naspool
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 0 in 14h33m with 0 errors on Sun Jun 28 14:34:15 2015
naspool ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/2ac3e730-df5b-c4c3-905b-a78dedb9bc87 ONLINE 0 0 0
gptid/65d27b4d-cdb0-a063-964a-dff6df744e43 ONLINE 0 0 0
gptid/0cabf044-ea4f-8140-b179-c585b5b9b589 ONLINE 0 0 0
gptid/8a16f35f-4cbd-b368-f186-a152a44021bc ONLINE 0 0 0
gptid/09917131-9964-cb6d-e163-c365b8a534d1 ONLINE 0 0 0
