I updated FreeNAS system a few days ago, at this time I also activated the periodical SMART inspections.
My hard drives are
5 x Western Digital WD30EFRX Red 3TB (RAID-Z2)
1 x Seagate Archive HDD v2 8TB
the rest of the hardware is a HP MicroServer N36L (8 GB RAM).
Unfortunately I now get daily critical warning messages. I'm not sure where this comes from.
From the FreeNAS overview page:
smartctl of /dev/ada2
smartctl of Seagate v2 Archive HDD 8 TB
zpool status
My hard drives are
KRITISCH: Device: /dev/ada4, Read SMART Error Log Failed
KRITISCH: Device: /dev/ada4, failed to read SMART Attribute Data
KRITISCH: Device: /dev/ada2, Self-Test Log error count increased from 0 to 1
~# smartctl -a /dev/ada2 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red (AF) Device Model: WDC WD30EFRX-68EUZN0 Serial Number: WD-WMC4N1076300 LU WWN Device Id: 5 0014ee 6040455e9 Firmware Version: 80.00A80 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Sat Aug 1 12:00:30 2015 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (40680) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 408) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 178 176 021 Pre-fail Always - 6100 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 53 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 13681 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 53 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 45 193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 740610 194 Temperature_Celsius 0x0022 119 114 000 Old_age Always - 31 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 13672 204275648 # 2 Short offline Completed without error 00% 38 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
~# smartctl -a /dev/ada4 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: ST8000AS0002-1NA17Z Serial Number: Z8406KXS LU WWN Device Id: 5 000c50 07b7fc021 Firmware Version: AR13 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 5980 rpm Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Sat Aug 1 12:01:12 2015 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Warning! SMART Attribute Data Structure error: invalid SMART checksum. Read SMART Thresholds failed: Input/output error === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x00) Offline data collection not supported. SMART capabilities: (0x0000) Automatic saving of SMART data is not implemented. Error logging capability: (0x00) Error logging supported. General Purpose Logging supported. SCT capabilities: (0x30a5) SCT Status supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 3162 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 255 Unknown_Attribute 0x373f 200 016 --- Pre-fail Always - 69269232549888 32 Unknown_Attribute 0x2020 032 032 --- Old_age Offline - 82687521601568 83 Unknown_Attribute 0x0658 123 039 --- Old_age Offline - 56355641622643 32 Unknown_Attribute 0x2020 032 084 --- Old_age Offline - 91466432524371 48 Unknown_Attribute 0x3230 048 049 --- Old_age Offline - 35395753361709 32 Unknown_Attribute 0x2020 032 032 --- Old_age Offline - 35322350018592 32 Unknown_Attribute 0x2020 032 032 --- Old_age Offline - 550026354720 16 Unknown_Attribute 0x3f00 000 016 --- Old_age Offline - 280775165541372 255 Unknown_Attribute 0x000f 000 007 --- Pre-fail Always - 131943408599808 120 Unknown_Attribute 0x7800 000 000 --- Old_age Offline - 0 68 Unknown_Attribute 0xf000 003 031 --- Old_age Offline - 109390152887040 105 Unknown_Attribute 0x4134 188 099 --- Old_age Offline - 238052190486369 32 Unknown_Attribute 0x0220 000 064 --- Old_age Offline - 6940667217921 10 Spin_Retry_Count 0x003c 000 060 --- Old_age Offline - 134217728 132 Unknown_Attribute 0x0001 139 008 --- Pre-fail Offline - 128 255 Unknown_Attribute 0xbd00 239 000 --- Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] Selective Self-tests/Logging not supported
zpool status
~# zpool status pool: bpool state: ONLINE scan: none requested config: NAME STATE READ WRITE CKSUM bpool ONLINE 0 0 0 gptid/04bebf57-32cd-11e5-bbc2-6805ca1b4fa6 ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE status: One or more devices are configured to use a non-native block size. Expect reduced performance. action: Replace affected devices with devices that support the configured block size, or migrate data to a properly configured pool. scan: scrub repaired 0 in 0h1m with 0 errors on Sun Jul 12 03:46:11 2015 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 da0p2 ONLINE 0 0 0 block size: 512B configured, 8388608B native da1p2 ONLINE 0 0 0 errors: No known data errors pool: naspool state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 14h33m with 0 errors on Sun Jun 28 14:34:15 2015 config: NAME STATE READ WRITE CKSUM naspool ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/2ac3e730-df5b-c4c3-905b-a78dedb9bc87 ONLINE 0 0 0 gptid/65d27b4d-cdb0-a063-964a-dff6df744e43 ONLINE 0 0 0 gptid/0cabf044-ea4f-8140-b179-c585b5b9b589 ONLINE 0 0 0 gptid/8a16f35f-4cbd-b368-f186-a152a44021bc ONLINE 0 0 0 gptid/09917131-9964-cb6d-e163-c365b8a534d1 ONLINE 0 0 0 errors: No known data errors
