One or more devices has experienced an unrecoverable error?
nagiltt
Hello, I build a NAS a few weeks ago, so Im still a bit new. I got a weird Error yesterday:
CRITICAL
Pool Storage state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected..
I dont really know what's wrong with it, I did a s.m.a.r.t. test on the drives just to see if some of them are broken but I'm not sure what to look for..
This is my setup:
i5-6500, 8GB RAM DDR4, 3x1TB WD Purple HHD and a M.2 240GB SSD as a cache.
This is what I got from the shell:
Thanks a lot for the help :)
root@NAGINAS[~]# smartctl -a /dev/ada0
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p6 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: WDC WD10PURZ-85U8XY0
Serial Number: WD-WCC4J5RNXDC3
LU WWN Device Id: 5 0014ee 2b973ca8a
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 5400 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Mar 12 19:18:10 2020 CET
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (14100) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 160) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 149 127 021 Pre-fail Always - 3541
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 263
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4079
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 158
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 78
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 185
194 Temperature_Celsius 0x0022 106 100 000 Old_age Always - 37
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 4061 -
# 2 Short offline Completed without error 00% 4058 -
# 3 Short offline Completed without error 00% 4058 -
# 4 Short offline Completed without error 00% 4058 -
# 5 Short offline Completed without error 00% 4058 -
# 6 Short offline Completed without error 00% 3567 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@NAGINAS[~]# smartctl -a /dev/ada1
Serial Number: WD-WCC4J6NXS2TD
LU WWN Device Id: 5 0014ee 2b9cc7fdb
Local Time is: Thu Mar 12 19:18:51 2020 CET
was never started.
been run.
data collection: (12840) seconds.
command.
power-saving mode.
recommended polling time: ( 147) minutes.
3 Spin_Up_Time 0x0027 153 129 021 Pre-fail Always - 3333
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 262
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3062
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 157
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 77
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 184
194 Temperature_Celsius 0x0022 106 101 000 Old_age Always - 37
No Errors Logged
# 1 Extended offline Completed without error 00% 3045 -
# 2 Short offline Completed without error 00% 3042 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@NAGINAS[~]# smartctl -a /dev/ada2
Serial Number: WD-WCC4J0UTRPUZ
LU WWN Device Id: 5 0014ee 20ec9505f
Local Time is: Thu Mar 12 19:19:00 2020 CET
was never started.
been run.
data collection: (13800) seconds.
command.
power-saving mode.
recommended polling time: ( 157) minutes.
3 Spin_Up_Time 0x0027 153 131 021 Pre-fail Always - 3308
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 248
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4081
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 170
194 Temperature_Celsius 0x0022 108 099 000 Old_age Always - 35
No Errors Logged
# 1 Extended offline Completed without error 00% 4063 -
# 2 Short offline Completed without error 00% 4060 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@NAGINAS[~]# smartctl -a /dev/da1
Model Number: SAMSUNG MZFLV256HCHP-000MV
Serial Number: S245NACGB88104
Firmware Version: BXV75M0Q
PCI Vendor/Subsystem ID: 0x144d
IEEE OUI Identifier: 0x002538
Controller ID: 1
Number of Namespaces: 1
Namespace 1 Size/Capacity: 256,060,514,304 [256 GB]
Namespace 1 Utilization: 29,178,368,000 [29.1 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 002538 4bf102a2b2
Local Time is: Thu Mar 12 19:19:09 2020 CET
Firmware Updates (0x06): 3 Slots
Optional Admin Commands (0x0006): Format Frmw_DL
Optional NVM Commands (0x001f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 6.00W - - 0 0 0 0 5 5
1 + 4.20W - - 1 1 1 1 30 30
2 + 3.10W - - 2 2 2 2 100 100
3 - 0.0700W - - 3 3 3 3 500 5000
4 - 0.0050W - - 4 4 4 4 2000 22000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
1 - 4096 0 0
=== START OF SMART DATA SECTION ===
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 60 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 2%
Data Units Read: 13,809,377 [7.07 TB]
Data Units Written: 15,346,363 [7.85 TB]
Host Read Commands: 265,192,772
Host Write Commands: 209,937,048
Controller Busy Time: 3,208
Power Cycles: 1,419
Power On Hours: 1,129
Unsafe Shutdowns: 133
Media and Data Integrity Errors: 37,188
Error Information Log Entries: 38,428
Error Information (NVMe Log 0x01, max 64 entries)
Num ErrCount SQId CmdId Status PELoc LBA NSID VS
0 38428 1 0x005e 0x4502 0x000 0 1 -
1 38427 1 0x0049 0x4502 0x000 0 1 -
2 38426 1 0x002d 0x4502 0x000 0 1 -
3 38425 1 0x0054 0x4502 0x000 0 1 -
4 38424 1 0x0070 0x4502 0x000 0 1 -
5 38423 1 0x002f 0x4502 0x000 0 1 -
6 38422 1 0x0019 0x4502 0x000 0 1 -
7 38421 1 0x0007 0x4502 0x000 0 1 -
8 38420 1 0x002c 0x4502 0x000 0 1 -
9 38419 1 0x007b 0x4502 0x000 0 1 -
10 38418 1 0x005a
I suggest you follow the troubleshooting steps in the resource Hard Drive Troubleshooting Guide (All Versions of FreeNAS). When providing the output of SMART status results, remember to include it within code tags to improve the readability of the thread e.g.
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Controller ID: 1
0 + 512 0 0
1 - 4096 0 0
Percentage Used: 2%
Power Cycles: 1,419
10 38418 1 0x005a
Redcoat
Observing @Basil Hendroff request above, please give us the results of zpool status and describe your boot device
