Resource icon
SLOG benchmarking and finding the best SLOG
Kevin666
Annybody tried a samsung PM9a3 ? they seem cheap and fast, although i cant find the latency in their documentation.
Kevin666
I got these rapports over a 1GB intel raidcard just for giggles with intel SSD 540s
How do you guys get the info in that code - format ?
Kailee71
Simple... you type
HoneyBadger
actually does care
Administrator
(Interrupt throttling) happens on the smaller block sizes; anything up to 8-16KiB. I'm now thinking it is this throttling that might be hampering the performance with those small block sizes, as for the larger block sizes the performance is comparable to when power management is set to performance. Is there a way to circumvent the throttling other than changing the power mngmt setting to test this hypothesis? I'm hoping I'd be able to have power management set balanced and still have the higher performing log devices (total power draw goes up from ~140W to ~250W on idle)...
I don't believe so. The power management is constantly trying to get the CPU/PCIe link/everything it can to shift into a lower power state, and there's probably just enough time between disk writes (whether waiting for disk, waiting on PCIe link, or waiting on vmkernel) to have it constantly toggling between them and spewing interrupts all over VMware.
Full-throttle mode causes it to never go to sleep, but at the cost of significantly higher idle power consumption.
Sorry. Don't think there's an easy win here. Solar panels to offset the consumption maybe?
Stux
Another P4801X 100GB optane.
This time in a Supermicro X10SRi-F
smart results
root@titan:~ # smartctl -a /dev/nvme0
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build)
Model Number:                       INTEL SSDPEL1K100GA
Serial Number:                      PHKM034100FX100D
Firmware Version:                   E2010485
PCI Vendor/Subsystem ID:            0x8086
IEEE OUI Identifier:                0x5cd2e4
Controller ID:                      0
NVMe Version:                       <1.2
Number of Namespaces:               1
Namespace 1 Size/Capacity:          100,030,242,816 [100 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            5cd2e4 b6f07b0100
Local Time is:                      Mon Jul 26 16:14:19 2021 AEST
Firmware Updates (0x02):            1 Slot
Optional Admin Commands (0x0007):   Security Format Frmw_DL
Optional NVM Commands (0x0006):     Wr_Unc DS_Mngmt
Log Page Attributes (0x0a):         Cmd_Eff_Lg Telmtry_Lg
Maximum Data Transfer Size:         32 Pages
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
0 +    10.00W       -        -    0  0  0  0        0       0
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
0 +     512       0         2
1 -     512       8         2
2 -     512      16         2
3 -    4096       0         0
4 -    4096       8         0
5 -    4096      64         0
6 -    4096     128         0
=== START OF SMART DATA SECTION ===
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        43 Celsius
Available Spare:                    100%
Available Spare Threshold:          0%
Percentage Used:                    0%
Data Units Read:                    6 [3.07 MB]
Data Units Written:                 17,507 [8.96 GB]
Host Read Commands:                 280
Host Write Commands:                416,250
Controller Busy Time:               0
Power Cycles:                       4
Power On Hours:                     0
Unsafe Shutdowns:                   0
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
First results at 512k sector size
root@titan:~ # diskinfo -wS /dev/nvd0
/dev/nvd0
    512             # sectorsize
    100030242816    # mediasize in bytes (93G)
    195371568       # mediasize in sectors
    0               # stripesize
    0               # stripeoffset
    INTEL SSDPEL1K100GA    # Disk descr.
    PHKM034100FX100D    # Disk ident.
    Yes             # TRIM/UNMAP support
    0               # Rotation rate in RPM
Synchronous random writes:
     0.5 kbytes:     19.6 usec/IO =     24.9 Mbytes/s
       1 kbytes:     16.7 usec/IO =     58.6 Mbytes/s
       2 kbytes:     17.3 usec/IO =    112.7 Mbytes/s
       4 kbytes:     13.4 usec/IO =    290.5 Mbytes/s
       8 kbytes:     19.0 usec/IO =    411.8 Mbytes/s
      16 kbytes:     27.7 usec/IO =    564.5 Mbytes/s
      32 kbytes:     43.4 usec/IO =    720.1 Mbytes/s
      64 kbytes:     74.8 usec/IO =    835.3 Mbytes/s
     128 kbytes:    148.1 usec/IO =    844.0 Mbytes/s
     256 kbytes:    285.2 usec/IO =    876.6 Mbytes/s
     512 kbytes:    516.2 usec/IO =    968.7 Mbytes/s
    1024 kbytes:    971.7 usec/IO =   1029.1 Mbytes/s
    2048 kbytes:   1878.6 usec/IO =   1064.6 Mbytes/s
    4096 kbytes:   3702.5 usec/IO =   1080.4 Mbytes/s
    8192 kbytes:   7344.9 usec/IO =   1089.2 Mbytes/s
Wasn't 100% happy so tried to enter the bios. That's when I found that the bios setup was hanging.
This box is on 2.0 bios, so upgraded to 3.3 bios (latest)
Tried power fiddles before bios update (which invovled pulling the card a few times), but that made no difference.
The bios updated fixed the hang, and added PCIe Bifurcation settings, so that's a win :)
I split the x16 slot into x4x4x4x4 (not needed yet, but I plan to get a quad carrier card)
And then re-ran the bench.
     0.5 kbytes:     16.2 usec/IO =     30.2 Mbytes/s
       1 kbytes:     16.5 usec/IO =     59.3 Mbytes/s
       2 kbytes:     17.1 usec/IO =    114.5 Mbytes/s
       4 kbytes:     14.2 usec/IO =    275.3 Mbytes/s
       8 kbytes:     17.6 usec/IO =    442.7 Mbytes/s
      16 kbytes:     26.7 usec/IO =    585.7 Mbytes/s
      32 kbytes:     42.5 usec/IO =    735.5 Mbytes/s
      64 kbytes:     74.8 usec/IO =    836.1 Mbytes/s
     128 kbytes:    148.7 usec/IO =    840.6 Mbytes/s
     256 kbytes:    282.9 usec/IO =    883.8 Mbytes/s
     512 kbytes:    514.8 usec/IO =    971.3 Mbytes/s
    1024 kbytes:    967.6 usec/IO =   1033.4 Mbytes/s
    2048 kbytes:   1883.4 usec/IO =   1061.9 Mbytes/s
    4096 kbytes:   3703.2 usec/IO =   1080.2 Mbytes/s
    8192 kbytes:   7340.4 usec/IO =   1089.9 Mbytes/s
a measurable improvement. power management is "let the os do it" and putting it on bios + performance doesn't seem to make a difference.
Next I switched the sector size to 4KB. This means using Intel Memory And Storage tool. This is available for Linux, so I installed it in a VM, added the Optane to the PCI pass-thru list, reboot, add the PCI device to the VM. boot that...
then checked the firwmare was up2date... it was and, reformatted:
intelmas start -intelssd 0 -nvmeformat LBAformat = 3
shutdown vm, remove pci device, remove from pass-thru list, and reboot..
and then we can test with 4096B sectors.
/dev/nvd0
    4096            # sectorsize
    24421446        # mediasize in sectors
    0               # stripesize
    0               # stripeoffset
       4 kbytes:     13.1 usec/IO =    298.6 Mbytes/s
       8 kbytes:     17.1 usec/IO =    456.2 Mbytes/s
      16 kbytes:     27.6 usec/IO =    565.7 Mbytes/s
      32 kbytes:     42.5 usec/IO =    735.9 Mbytes/s
      64 kbytes:     72.9 usec/IO =    856.9 Mbytes/s
     128 kbytes:    135.1 usec/IO =    925.3 Mbytes/s
     256 kbytes:    255.5 usec/IO =    978.5 Mbytes/s
     512 kbytes:    509.0 usec/IO =    982.4 Mbytes/s
    1024 kbytes:    972.2 usec/IO =   1028.6 Mbytes/s
    2048 kbytes:   1879.6 usec/IO =   1064.1 Mbytes/s
    4096 kbytes:   3693.3 usec/IO =   1083.0 Mbytes/s
    8192 kbytes:   7320.3 usec/IO =   1092.8 Mbytes/s
That'll do :)
bonus:
Repartitioning after removing manually after TrueNAS formatted
root@titan:~ # gpart show nvd0
=>       6  24421435  nvd0  GPT  (93G)
         6       122        - free -  (488K)
       128  24421313     1  freebsd-zfs  (93G)
root@titan:~ # gpart delete -i 1 nvd0
nvd0p1 deleted
root@titan:~ # gpart add -i 1 -t freebsd-zfs -a 512k -s 16G nvd0
nvd0p1 added
       128   4194304     1  freebsd-zfs  (16G)
   4194432  20227009        - free -  (77G)
Benched that a bit... saw it *almost* filling up... so repartitioned to 32G.
And i'm actually seeing it hit 1.08GB/s write with iostat, and some SMB 10gbe traffic.
32G means there's plenty of space, but I can still create additional SLOGs for another pool or two if I wanted to.
PS: A drive was resilvering during this testing session, not sure how much that affected things... oh well. This is in service now.
QonoS
Micron 5100 MAX 1.92TB SATA
root@truenas[~]# smartctl -a /dev/ada1
Model Family:     Micron 5100 Pro / 52x0 / 5300 SSDs
Device Model:     Micron_5100_MTFDDAK1T9TCC
Serial Number:    ---
LU WWN Device Id: ---
Firmware Version: D0MU075
User Capacity:    1,920,383,410,176 bytes [1.92 TB]
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Aug  3 15:17:26 2021 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                ( 6697) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  14) minutes.
Conveyance self-test routine
recommended polling time:        (   3) minutes.
SCT capabilities:              (0x0035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   100   050    Pre-fail  Always       -       21
  5 Reallocated_Sector_Ct   0x0032   100   100   001    Old_age   Always       -       95
  9 Power_On_Hours          0x0032   100   100   001    Old_age   Always       -       29340
12 Power_Cycle_Count       0x0032   100   100   001    Old_age   Always       -       71
170 Reserved_Block_Pct      0x0033   100   100   010    Pre-fail  Always       -       95
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   001    Old_age   Always       -       0
173 Avg_Block-Erase_Count   0x0032   099   099   000    Old_age   Always       -       83
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       55
183 SATA_Int_Downshift_Ct   0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       20
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       123
194 Temperature_Celsius     0x0022   065   059   000    Old_age   Always       -       35 (Min/Max 17/41)
195 Hardware_ECC_Recovered  0x0032   100   100   000    Old_age   Always       -       1
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       95
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       1
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
202 Percent_Lifetime_Remain 0x0030   099   099   001    Old_age   Offline      -       1
206 Write_Error_Rate        0x000e   100   100   000    Old_age   Always       -       0
246 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       326665288896
247 Host_Program_Page_Count 0x0032   100   100   000    Old_age   Always       -       10195047722
248 Bckgnd_Program_Page_Cnt 0x0032   100   100   000    Old_age   Always       -       7222013067
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033   000   000   000    Pre-fail  Always       -       55014
210 RAIN_Success_Recovered  0x0032   100   100   000    Old_age   Always       -       1468
211 Integ_Scan_Complete_Cnt 0x0032   100   100   000    Old_age   Always       -       4
212 Integ_Scan_Folding_Cnt  0x0032   100   100   000    Old_age   Always       -       2
root@truenas[~]# diskinfo -wS /dev/ada1
/dev/ada1
        512             # sectorsize
        1920383410176   # mediasize in bytes (1.7T)
        3750748848      # mediasize in sectors
        4096            # stripesize
        0               # stripeoffset
        3720981         # Cylinders according to firmware.
        16              # Heads according to firmware.
        63              # Sectors according to firmware.
        Micron 5100 MTFDDAK1T9TCC       # Disk descr.
        ---    # Disk ident.
        Not_Zoned       # Zone Mode
         0.5 kbytes:     63.2 usec/IO =      7.7 Mbytes/s
           1 kbytes:     63.1 usec/IO =     15.5 Mbytes/s
           2 kbytes:     65.5 usec/IO =     29.8 Mbytes/s
           4 kbytes:     65.2 usec/IO =     59.9 Mbytes/s
           8 kbytes:     72.5 usec/IO =    107.7 Mbytes/s
          16 kbytes:     89.3 usec/IO =    175.0 Mbytes/s
          32 kbytes:    121.5 usec/IO =    257.2 Mbytes/s
          64 kbytes:    185.8 usec/IO =    336.4 Mbytes/s
         128 kbytes:    316.6 usec/IO =    394.9 Mbytes/s
         256 kbytes:    566.5 usec/IO =    441.3 Mbytes/s
         512 kbytes:   1070.2 usec/IO =    467.2 Mbytes/s
        1024 kbytes:   2085.4 usec/IO =    479.5 Mbytes/s
        2048 kbytes:   4078.0 usec/IO =    490.4 Mbytes/s
        4096 kbytes:   8079.1 usec/IO =    495.1 Mbytes/s
        8192 kbytes:  15873.4 usec/IO =    504.0 Mbytes/s
Leo Fender
I don't remember seeing any results of this drive yet, so here is my fresh out of the box Samsung 883 DCT 480GB:
root@truenas[/]# smartctl -a /dev/ada4
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build)
Model Family:     Samsung based SSDs
Device Model:     Samsung SSD 883 DCT 480GB
Serial Number:    --REDACTED--
LU WWN Device Id: --REDACTED--
Firmware Version: HXT7904Q
User Capacity:    480,103,981,056 bytes [480 GB]
ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
Local Time is:    Thu Aug 19 18:57:47 2021 AEST
                    was never started.
                    been run.
data collection:         (    0) seconds.
capabilities:              (0x53) SMART execute Offline immediate.
                    command.
                    No Offline surface scan supported.
                    power-saving mode.
recommended polling time:      (  35) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
SMART Attributes Data Structure revision number: 1
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       2
177 Wear_Leveling_Count     0x0013   100   100   005    Pre-fail  Always       -       0
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0013   100   100   010    Pre-fail  Always       -       1432
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
184 End-to-End_Error        0x0033   100   100   097    Pre-fail  Always       -       0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   073   070   000    Old_age   Always       -       27
194 Temperature_Celsius     0x0022   073   060   000    Old_age   Always       -       27 (Min/Max 19/30)
195 ECC_Error_Rate          0x001a   200   200   000    Old_age   Always       -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
202 Exception_Mode_Status   0x0033   100   100   010    Pre-fail  Always       -       0
235 POR_Recovery_Count      0x0012   100   100   000    Old_age   Always       -       0
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       0
242 Total_LBAs_Read         0x0032   099   099   000    Old_age   Always       -       6301
243 SATA_Downshift_Ct       0x0032   100   100   000    Old_age   Always       -       0
244 Thermal_Throttle_St     0x0032   100   100   000    Old_age   Always       -       0
245 Timed_Workld_Media_Wear 0x0032   100   100   000    Old_age   Always       -       65535
246 Timed_Workld_RdWr_Ratio 0x0032   100   100   000    Old_age   Always       -       65535
247 Timed_Workld_Timer      0x0032   100   100   000    Old_age   Always       -       65535
251 NAND_Writes             0x0032   100   100   000    Old_age   Always       -       0
root@truenas[/]# diskinfo -wS /dev/ada4
/dev/ada4
    512             # sectorsize
    480103981056    # mediasize in bytes (447G)
    937703088       # mediasize in sectors
    4096            # stripesize
    0               # stripeoffset
    930261          # Cylinders according to firmware.
    Samsung SSD 883 DCT 480GB    # Disk descr.
    --REDACTED--    # Disk ident.
     0.5 kbytes:     41.7 usec/IO =     11.7 Mbytes/s
       1 kbytes:     42.5 usec/IO =     23.0 Mbytes/s
       2 kbytes:     44.2 usec/IO =     44.2 Mbytes/s
       4 kbytes:     47.4 usec/IO =     82.4 Mbytes/s
       8 kbytes:     54.4 usec/IO =    143.6 Mbytes/s
      16 kbytes:     75.7 usec/IO =    206.3 Mbytes/s
      32 kbytes:    108.1 usec/IO =    289.0 Mbytes/s
      64 kbytes:    173.0 usec/IO =    361.2 Mbytes/s
     128 kbytes:    302.8 usec/IO =    412.8 Mbytes/s
     256 kbytes:    571.9 usec/IO =    437.1 Mbytes/s
     512 kbytes:   1136.0 usec/IO =    440.2 Mbytes/s
    1024 kbytes:   2220.9 usec/IO =    450.3 Mbytes/s
    2048 kbytes:   4390.1 usec/IO =    455.6 Mbytes/s
    4096 kbytes:   8701.8 usec/IO =    459.7 Mbytes/s
    8192 kbytes:  17365.9 usec/IO =    460.7 Mbytes/s
For a SATA drive, I'm quite happy with these numbers.
Also, just for fun, here is a not so fresh Samsung 860 EVO 1TB:
Device Model:     Samsung SSD 860 EVO 1TB
Firmware Version: RVT04B6Q
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Local Time is:    Thu Aug 19 18:02:03 2021 AEST
                    was never started.
                    been run.
                    command.
                    power-saving mode.
recommended polling time:      (  85) minutes.
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       4168
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       85
177 Wear_Leveling_Count     0x0013   099   099   000    Pre-fail  Always       -       5
190 Airflow_Temperature_Cel 0x0032   076   057   000    Old_age   Always       -       24
235 POR_Recovery_Count      0x0012   099   099   000    Old_age   Always       -       25
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       8780283195
/dev/ada4
    512             # sectorsize
    1000204886016    # mediasize in bytes (932G)
    1953525168      # mediasize in sectors
    0               # stripesize
    0               # stripeoffset
    1938021         # Cylinders according to firmware.
    Samsung SSD 860 EVO 1TB    # Disk descr.
     0.5 kbytes:    669.2 usec/IO =      0.7 Mbytes/s
       1 kbytes:    705.6 usec/IO =      1.4 Mbytes/s
       2 kbytes:    672.4 usec/IO =      2.9 Mbytes/s
       4 kbytes:    670.0 usec/IO =      5.8 Mbytes/s
       8 kbytes:    649.8 usec/IO =     12.0 Mbytes/s
      16 kbytes:    666.7 usec/IO =     23.4 Mbytes/s
      32 kbytes:    736.1 usec/IO =     42.5 Mbytes/s
      64 kbytes:    847.5 usec/IO =     73.8 Mbytes/s
     128 kbytes:   1098.1 usec/IO =    113.8 Mbytes/s
     256 kbytes:   1530.7 usec/IO =    163.3 Mbytes/s
     512 kbytes:   1721.0 usec/IO =    290.5 Mbytes/s
    1024 kbytes:   2836.5 usec/IO =    352.6 Mbytes/s
    2048 kbytes:   5078.4 usec/IO =    393.8 Mbytes/s
    4096 kbytes:   9496.4 usec/IO =    421.2 Mbytes/s
    8192 kbytes:  17990.0 usec/IO =    444.7 Mbytes/s
rshakin
RMS-200 Quick Update, Was going to see if I could be there for when it hit 500pb but missed it by a little
root@freenas[~]# smartctl -a /dev/nvme0
Model Number:                       RMS-200
Serial Number:                      0085217
Firmware Version:                   ae34b8cc
PCI Vendor/Subsystem ID:            0x1cc7
IEEE OUI Identifier:                0x00e0cf
Controller ID:                      0
NVMe Version:                       <1.2
Namespace 1 Size/Capacity:          8,581,545,984 [8.58 GB]
Namespace 1 Utilization:            0
Local Time is:                      Thu Aug 26 21:58:21 2021 PDT
Firmware Updates (0x09):            4 Slots, Slot 1 R/O
Optional Admin Commands (0x0006):   Format Frmw_DL
Log Page Attributes (0x01):         S/H_per_NS
 0 +    25.00W       -        -    0  0  0  0      100     100
 0 -     512       0         3
 1 -     512       8         3
 2 -    4096       0         0
 3 -    4096       8         0
Temperature:                        52 Celsius
Available Spare:                    0%
Percentage Used:                    0%
Data Units Read:                    95,516,794,919 [48.9 PB]
Data Units Written:                 1,006,800,245,478 [515 PB]
Host Read Commands:                 1,148,560,059
Host Write Commands:                9,453,074,925
Controller Busy Time:               931,385
Power Cycles:                       42
Power On Hours:                     22,542
Unsafe Shutdowns:                   36
Error Information Log Entries:      1
Error Information (NVMe Log 0x01, 16 of 63 entries)
No Errors Logged
root@freenas[~]#
NugentS
Wow. I notice that techbuyer have one listed on Ebay UK, as a graphics card!!
Now gone
:smile:
HoneyBadger
actually does care
Administrator
Even Optane would be burning out at that kind of write load I have to imagine.
Side note - did yours come with the FH bracket or is it not needed for your setup?
rshakin
I am pretty sure it's half bracket stock one. I am hoping it wont get taken out of commission before we hit 1000PB that would be cool, but we will see if that will happen. We had to replace some things in that system already so might be getting close to that time of getting scrapped, but maybe if it runs for another year or so we shall hit the 1000 and that would be just cool.
Kailee71
And another RMS-200... Not sure whether the total written is a concern (>800PB:eek:)... but got it cheap just to try out. Nothing tuned at all, just threw it into my trusty old HPE Microserver G8;
root@waldorf[~]# smartctl -a /dev/nvme0 |less
Serial Number:                      0031867
Controller ID:                      0
NVMe Version:                       <1.2
Local Time is:                      Wed Sep  1 12:27:39 2021 BST
 0 -     512       0         3
 1 -     512       8         3
 2 -    4096       0         0
 3 -    4096       8         0
Temperature:                        36 Celsius
Available Spare:                    0%
Percentage Used:                    0%
Data Units Read:                    99,211,764,012 [50.7 PB]
Data Units Written:                 1,620,540,716,700 [829 PB]
Host Read Commands:                 455,532,805
Host Write Commands:                309,357,943,886
Controller Busy Time:               377
Power Cycles:                       19
Power On Hours:                     29,197
Unsafe Shutdowns:                   9
No Errors Logged
and
root@waldorf[~]# diskinfo -wS /dev/nvd0
/dev/nvd0
        512             # sectorsize
        8581545984      # mediasize in bytes (8.0G)
        16760832        # mediasize in sectors
        0               # stripesize
        0               # stripeoffset
        RMS-200         # Disk descr.
        0031867         # Disk ident.
         0.5 kbytes:     23.1 usec/IO =     21.1 Mbytes/s
           1 kbytes:     23.7 usec/IO =     41.3 Mbytes/s
           2 kbytes:     24.2 usec/IO =     80.6 Mbytes/s
           4 kbytes:     24.6 usec/IO =    159.0 Mbytes/s
           8 kbytes:     26.0 usec/IO =    300.8 Mbytes/s
          16 kbytes:     32.4 usec/IO =    481.8 Mbytes/s
          32 kbytes:     40.2 usec/IO =    777.7 Mbytes/s
          64 kbytes:     62.5 usec/IO =    999.4 Mbytes/s
         128 kbytes:     86.3 usec/IO =   1448.9 Mbytes/s
         256 kbytes:    117.4 usec/IO =   2130.0 Mbytes/s
         512 kbytes:    197.1 usec/IO =   2536.4 Mbytes/s
        1024 kbytes:    345.4 usec/IO =   2895.1 Mbytes/s
        2048 kbytes:    652.4 usec/IO =   3065.5 Mbytes/s
        4096 kbytes:   1225.1 usec/IO =   3265.1 Mbytes/s
        8192 kbytes:   2399.6 usec/IO =   3333.8 Mbytes/s
So up to 256kbytes ahead of @rshakin, thereafter I'm guessing there would be some BIOS tweaking needed. Leaving it alone as it will go into my DL380p next week.
Kailee71
Now gone
:smile:
... two left now ... ;-)
BTW I can fully recommend TechBuyer. Not affiliated in any way but have only fully positive experiences with them.
erthink
Apparently the auto-backup to flash functionality is disabled by default, and needs to be re-enabled on every boot. Auto-restore is also disabled by default but at least persists. I've requested access to the code/firmware, might need to go under NDA which will complicate things.
Could you help me with some cli-utilities and/or linux drivers for NV16xx?
Unfortunately, I couldn't find anything usable and downloads from PMC's site are no longer availale (for instance, from the "documentation" tab at http://216.241.235.166/products/storage/flashtec_nvram_drives/nv1616/).
I would be grateful for any information, especially for a source code of utilities and/or drivers (for any OS), etc.
rshakin
Trust Me Comrad I tried getting that stuff from them even got a hold of the main boys in development, no go, and everything is locked tight
rshakin
Controller ID:                      0
NVMe Version:                       <1.2
0 -     512       0         3
1 -     512       8         3
2 -    4096       0         0
3 -    4096       8         0
Available Spare:                    0%
Percentage Used:                    0%
Power Cycles:                       19
Unsafe Shutdowns:                   9
No Errors Logged
and
/dev/nvd0
        512             # sectorsize
        0               # stripesize
        0               # stripeoffset
I am wondering how you got it to that speed, but I think my system is set up to handle large files or maybe there is some kind of a tweak in there. What system did you test it on ?
Kailee71
Sorry for the delayed reply. System is a box-standard HPE Microserver G8 with the "standard" G1610T Celeron, 16Gb ECC, 2 Hitachi 2Tib drives, 2 WD 4Tib Reds as striped mirrors, and temporarily the RMS-200.
TrueNAS-12.0-U5.1 with no tunables. Nothing special *at all*. Just threw in the RMS and did the diskinfo. Let me know if you need any details, and how to get them. This system has no 10GbE so can't do any testing that means anything but I'm back home next week where the RMS will replace 2 32Gib Optanes in my production system... More testing will follow then.
Kailee71
And just for completions' sake, here is that same RMS-200 in my DL380p G8;
truenas# smartctl -a /dev/nvme0
Controller ID:                      0
NVMe Version:                       <1.2
Local Time is:                      Wed Sep 22 22:40:19 2021 CEST
0 -     512       0         3
1 -     512       8         3
2 -    4096       0         0
3 -    4096       8         0
Temperature:                        45 Celsius
Available Spare:                    0%
Percentage Used:                    0%
Data Units Read:                    99,211,766,494 [50.7 PB]
Data Units Written:                 1,622,149,164,390 [830 PB]
Host Read Commands:                 455,533,395
Host Write Commands:                309,372,726,826
Controller Busy Time:               386
Power Cycles:                       21
Power On Hours:                     29,198
Unsafe Shutdowns:                   10
No Errors Logged
and
truenas#  diskinfo -wS /dev/nvd0
/dev/nvd0
        512             # sectorsize
        0               # stripesize
        0               # stripeoffset
         0.5 kbytes:     45.3 usec/IO =     10.8 Mbytes/s
           1 kbytes:     45.4 usec/IO =     21.5 Mbytes/s
           2 kbytes:     49.2 usec/IO =     39.7 Mbytes/s
           4 kbytes:     48.3 usec/IO =     80.9 Mbytes/s
           8 kbytes:     52.0 usec/IO =    150.2 Mbytes/s
          16 kbytes:     60.0 usec/IO =    260.4 Mbytes/s
          32 kbytes:     69.9 usec/IO =    447.0 Mbytes/s
          64 kbytes:     82.2 usec/IO =    760.0 Mbytes/s
         128 kbytes:    151.3 usec/IO =    826.2 Mbytes/s
         256 kbytes:    203.2 usec/IO =   1230.5 Mbytes/s
         512 kbytes:    239.7 usec/IO =   2086.0 Mbytes/s
        1024 kbytes:    358.0 usec/IO =   2792.9 Mbytes/s
        2048 kbytes:    589.1 usec/IO =   3395.0 Mbytes/s
        4096 kbytes:   1060.2 usec/IO =   3772.9 Mbytes/s
        8192 kbytes:   1921.4 usec/IO =   4163.6 Mbytes/s
truenas#
Hm.... Instrumenting, as my little girl used to say. Will need to check out why small I/O breaks down so badly. It's not until1024kbytes that it catches up. I sense some BIOS tweaking coming. Anybody have an idea before I reboot a few dozen times?
In the mean time; a quick comparison chart:
Andrew32
Here is the test from the HP 400GB MS000400KWDUR with current firmware HPK4. Using the HP Dual M.2 NVMe adapter PCIe 3.0 x4 in a DL380p G8. Th nice thing about the HP card the huge heatsink that this SSD needs. The HP card supports 2 SSD but the G8 does not. The SSD is just a Seagate Nytro 5000 but HP branded (and HP firmware). This is the Mixed Use SSD version HP rates at 3 DWPD but Seagate rates it at 1.5 DWPD which is still better than the 0.3 DWPD for the standard version. The SSD DOES have on-board PLP. Read speed is about 550MB/s max. The 800GB version should have better speed (double?).
# smartctl -a /dev/nvme3
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p7 amd64] (local build)
Model Number:                       MS000400KWDUR
Serial Number:                      Z8W016B3
Firmware Version:                   HPK4
PCI Vendor ID:                      0x1bb1
PCI Vendor Subsystem ID:            0x1590
IEEE OUI Identifier:                0x0004cf
Controller ID:                      0
NVMe Version:                       1.2
Namespace 1 Size/Capacity:          400,088,457,216 [400 GB]
Namespace 1 Formatted LBA Size:     4096
Namespace 1 IEEE EUI-64:            19b600 1080cf0400
Local Time is:                      Tue Oct 19 13:13:05 2021 EDT
Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Log Page Attributes (0x03):         S/H_per_NS Cmd_Eff_Lg
Maximum Data Transfer Size:         64 Pages
Warning  Comp. Temp. Threshold:     65 Celsius
Critical Comp. Temp. Threshold:     70 Celsius
 0 +     8.25W       -        -    0  0  0  0      100     100
 1 +     6.00W       -        -    1  1  1  1      100     100
 2 +     4.50W       -        -    2  2  2  2      100     100
 0 +    4096       0         1
 1 -     512       0         3
Available Spare Threshold:          20%
Percentage Used:                    0%
Data Units Read:                    27,056 [13.8 GB]
Data Units Written:                 2,059,538 [1.05 TB]
Host Read Commands:                 114,970
Host Write Commands:                8,455,871
Controller Busy Time:               39
Power Cycles:                       24
Power On Hours:                     38
Unsafe Shutdowns:                   17
Error Information Log Entries:      3
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               36 Celsius
Temperature Sensor 2:               67 Celsius
No Errors Logged
# diskinfo -wS /dev/nvd3
/dev/nvd3
        4096            # sectorsize
        400088457216    # mediasize in bytes (373G)
        97677846        # mediasize in sectors
        0               # stripesize
        0               # stripeoffset
        MS000400KWDUR   # Disk descr.
        Z8W016B3        # Disk ident.
           4 kbytes:     34.7 usec/IO =    112.6 Mbytes/s
           8 kbytes:     37.9 usec/IO =    205.9 Mbytes/s
          16 kbytes:     43.6 usec/IO =    358.8 Mbytes/s
          32 kbytes:     68.4 usec/IO =    457.1 Mbytes/s
          64 kbytes:    133.0 usec/IO =    470.0 Mbytes/s
         128 kbytes:    264.4 usec/IO =    472.7 Mbytes/s
         256 kbytes:    524.6 usec/IO =    476.5 Mbytes/s
         512 kbytes:   1045.5 usec/IO =    478.2 Mbytes/s
        1024 kbytes:   2072.7 usec/IO =    482.5 Mbytes/s
        2048 kbytes:   4122.7 usec/IO =    485.1 Mbytes/s
        4096 kbytes:   8288.2 usec/IO =    482.6 Mbytes/s
        8192 kbytes:  16455.6 usec/IO =    486.2 Mbytes/s
kspare
SO what currently IS the fastest slog?
